李现路:在DSP6000中怎样编写您的第一个程序(二)
李现路:在DSP6000中怎样编写您的第一个程序(二)   Post By:2009-11-23 23:46:16
三、完整的中断向量表程序如下:
   .global _vectors ;定义一个能被外部(C语言程序)引用的变量
   .global _c_int00
   .global _vector1
   .global _vector2
   .global _vector3
   .global _vector1
   .global _vector5
   .global _vector6
   .global _vector7
   .global _vector8
   .global _vector9
   .global _vector10
   .global _vector11 ; Hookup the c_int08 ISR(连接这个中断设置寄存器) in main()
   .global _vector12    ; Hookup the c_int08 ISR in main()
   .global _vector13
   .global _vector14
   .global _vector15
完整版本请见http://www.51qianru.cn/bbs/
* Global symbols referenced in this file but defined somewhere else.
* Remember that your interrupt service routines need to be referenced here.
   .ref _c_int00 ;reset ISR(复位中断设置寄存), .ref表明一个或多个在另一个模块中定义而在前模块中要用到的符号
* This is a macro that instantiates one entry in the interrupt service table.
VEC_ENTRY .macro addr ;中断返回函数
    STW   B0,*--B15
    MVKL  addr,B0
    MVKH  addr,B0
    B     B0
    LDW   *B15++,B0
    NOP   2
    NOP
    NOP
   .endm
* This is a dummy interrupt service routine used to initialize the IST.
_vec_dummy:  ;初始化IST寄存器(中断向量表起始地址寄存器,用于设置中断服务程序存放的地址)
  B    B3
  NOP  5
* This is the actual interrupt service table (IST). It is properly aligned and
* is located in the subsection .text:vecs. This means if you don't explicitly
* specify this section in your linker command file, it will default and link
* into the .text section. Remember to set the ISTP(中断向量表起始地址寄存器) register to point to this
* table.
.sect ".vecs"  ;定义初始化带名称的段
.align 1024  ;分配程序页
_vectors:
_vector0:   VEC_ENTRY _c_int00    ;RESET(应用程序的入口)
_vector1:   VEC_ENTRY _vec_dummy  ;NMI(非屏蔽中断,用于处理极为关键的任务)
_vector2:   VEC_ENTRY _vec_dummy  ;RSVD
_vector3:   VEC_ENTRY _vec_dummy
_vector4:   VEC_ENTRY _vec_dummy
_vector5:   VEC_ENTRY _vec_dummy
_vector6:   VEC_ENTRY _vec_dummy
_vector7:   VEC_ENTRY _vec_dummy
_vector8:   VEC_ENTRY _vec_dummy
_vector9:   VEC_ENTRY _vec_dummy
_vector10:  VEC_ENTRY _vec_dummy
_vector11:  VEC_ENTRY _vec_dummy ; Hookup the c_int08 ISR in main()
_vector12:  VEC_ENTRY _vec_dummy    ; Hookup the c_int08 ISR in main()
_vector13:  VEC_ENTRY _vec_dummy
_vector14:  VEC_ENTRY _vec_dummy
_vector15:  VEC_ENTRY _vec_dummy
                                                        曙海教育
                                                曙海嵌入式学院3G通信培训中心
                                            (MTK培训,Android培训,iPhone培训)
                                                电话:021-51875830
                                                网址:http://www.51qianru.cn
                                                    讲师:李现路
                                         版权所有-曙海教育 转摘请注明作者和出处课程有:
