求助 MC9512XEP100 使用PIT定时30MS的范例
第一次用MC9512XEP100
以下例子和micro timer 0有什么关系呢
******************** Start PIT Initialization *******************************************************
CLR PITCFLMT ; disable PIT
MOVB #$01,PITCE ; enable timer channel 0
CLR PITMUX ; ch0 connected to micro timer 0
MOVB #$63,PITMTLD0 ; micro time base 0 equals 100 clock cycles
MOVW #$0004,PITLD0 ; time base 0 eq. 5 micro time bases 0 =5*100 = 500
MOVB #$01,PITINTE ; enable interupt channel 0
MOVB #$80,PITCFLMT ; enable PIT
CLI ; clear Interupt disable Mask bit |
