谁有MCS08DZ60的ADC程序,或者是demo程序也好,小弟学习学习!
看资料,编程序速度挺慢的,哪位大虾有现成的程序,小弟学习一下,感激不尽!
  龙丘MC9S08DZ60多功能开发板V2.0
  编写:龙丘
  Designed by Chiu Sir
  E-mail:chiusir@163.com
  软件版本:V1.0
  最后更新:2009年07月11日
  相关信息参考下列地址:
  博客:  http://longqiu.21ic.org
  淘宝店:http://shop36265907.taobao.com
#include "LQadc.h"
* ADC_Init: This function initilizes the ADC module
* Parameters:      none
* Subfunctions:    none.
* Return:          void
void ADC_Init(void)
     ADCCFG = 0x61;     //busclk/2, Div by 8,ADCK = 1.5MHz
                        /*  0b0000000 0
                         *    ||||||| |__ bit0,1: ADICLK : input clock select
                         *    |||||||_|
                         *    ||||||_____ bit2,3: MODE :  Conversion Mode selection
                         *    |||||_|
                         *    ||||______ bit4:    ADLSMP: long sample time configuration
                         *    |||_______ bit5,6 : ADIV:   Clock Divide Select
                         *    ||______|
                         *    |_________ bit7:    ADLPC:  Low power configuration
     ADCSC2 = 0x00;  //
                        /*  0b00000000
                         *    ||||||||__ bit0:
                         *    |||||||___ bit1:
                         *    ||||||____ bit2:
                         *    |||||_____ bit3:
                         *    ||||______ bit4: ACFGT: Compare function greater than enable
                         *    |||_______ bit5: ACFE : Compare enable
                         *    ||________ bit6: ADTRG: Conversion trigger select
                         *    |_________ bit7: ADACT: Convert active
    //ADCCFG |= 0x04; //BIT2--3      00:8BIT,01:12BIT,10:102BIT,11:RES
    /*Change the channel, to check the releation between pins and channels */
    APCTL1 = 0x00;  //disable all ADC ports0-19
    APCTL2 = 0x00;
    APCTL2 = 0xF0;
byte ADC_Cvt8B(unsigned char Channel)
   if(Channel<24)
    ADCSC1 =Channel;
   else return 0;
   while(!ADCSC1_COCO);
   return ADCRL;
飞思卡尔8/16/32位多功能开发板/下载器:
网站:http://www.lqist.cn,
可以用CodeWarrior的PE自动生成一个参考下,挺管用的。
谢谢指点!小弟这就去试试啦
