关于DE2上的LCD_16207的文件altera_avalon_lcd_16207.c中的lcd_handle_escape()代码
哪位兄弟帮我解释一下DE2上的液晶LCD_16207的文件altera_avalon_lcd_16207.c中的lcd_handle_escape()函数代码,看了几天实在看不明白,帮忙解释一下,谢谢!
static void lcd_handle_escape(alt_LCD_16207_dev * dev, char c)
  int parm1 = 0, parm2 = 0;                      //parm1和parm2两个变量起什么作用 ?
  if (dev->escape[0] == '[')                     //结构体中的escape数组是存放什么的?为什么要将escape[0]元素赋值'[',是用'['的ASCII代码091吗?
    char * ptr = dev->escape+1;                  //为什么要将指针ptr指向数组元素escape[1]?
    while (isdigit(*ptr))
      parm1 = (parm1 * 10) + (*ptr++ - '0');     //parm1开始不是被赋值0了吗?这里 parm1乘10不还是0吗?*ptr++ - '0'又是干什么呢?是变量*ptr减去'0'的ASCII代码048吗?
    if (*ptr == ';')                             //又为什么要变量*ptr等于';'才有下面的操作?
      ptr++;
        parm2 = (parm2 * 10) + (*ptr++ - '0');   //这几行是在干什么?
  else
    parm1 = -1;
  switch (c)
  case 'H': /* ESC '[' <y> ';' <x> 'H'  : Move cursor to location */  //如果是情况'H',是干什么?
  case 'f': /* Same as above */                                       //如果是情况'f',下面有是在干什么?
    if (parm2 > 0)
      dev->x = parm2 - 1;
    if (parm1 > 0)
      dev->y = parm1 - 1;
      if (dev->y > ALT_LCD_HEIGHT * 2)
        dev->y = ALT_LCD_HEIGHT * 2;
      while (dev->y > ALT_LCD_HEIGHT)
        lcd_scroll_up(dev);
    break;
  case 'J':                                                          //如果是情况'J',下面有是在干什么?
    /*   ESC J      is clear to beginning of line    [unimplemented]
     *   ESC [ 0 J  is clear to bottom of screen     [unimplemented]
     *   ESC [ 1 J  is clear to beginning of screen  [unimplemented]
     *   ESC [ 2 J  is clear screen
    if (parm1 == 2)
      lcd_clear_screen(dev);
    break;
  case 'K':                                                        //如果是情况'K',下面有是在干什么?
    /*   ESC K      is clear to end of line
     *   ESC [ 0 K  is clear to end of line
     *   ESC [ 1 K  is clear to beginning of line    [unimplemented]
     *   ESC [ 2 K  is clear line                    [unimplemented]
    if (parm1 < 1)
      if (dev->x < ALT_LCD_VIRTUAL_WIDTH)
        memset(dev->line[dev->y].data + dev->x, ' ', ALT_LCD_VIRTUAL_WIDTH - dev->x);
    break;
