s3c6410开发板产品原型机
s3c6410开发板产品原型机
CES-6410 Prototype Machine
n Functions and Features:
CES-6410 Prototype Machine is a development board based on the latest ARM1176 JZF-S core CPU S3C6410 produced by Samsung. The characteristics such as functions, cost and size have been very close to the following products: SUB NOTEBOOK, NETBOOK, EPC, MID, PMP, Advertising Machine, etc. This machine can greatly shorten the development cycle of products, and even a lot of products can directly use this prototype.
深圳市海天雄电子有限公司
联系人:车小姐
QQ1121944604
TEL0755-33019701-603
n Hardware resources:
n The core board hardware parameters (size: 53*83mm)
Ø Central processing unit (CPU):
Samsung S3C6410X, ARM1176JZF-S, Frequency 667MHZ
Ø Mobile DDR SDRAM:
128MB ~512MB, Mobile DDR SDRAM
Ø FLASH:1GB NAND FLASH
n The backplane hardware parameters (size:126*191mm)
Ø LCD interface:accessing to TFT,STN screen from 3.5 to 12.1-inch, standard TFT 7’(800*480)screen.
Ø Touch screen:Four-line resistance
Ø  TV output:one,composite video signal output, accessing to kinds  of TV
Ø S-VIDEO interface:one,S-VIDEO video signal output.
Ø TV input: one, composite video signal input
Ø  VGA interface:One, Standard VGA output interface.
Ø  Audio:one AC97, wolf’s WM9713
Ø  USB HOST:One USB HOST interface, adopting the restoration of self-insurance protection device to protect the external power system
Ø  USB OTG:One, USB 2.0 HS OTG
Ø   Serial port:three serial ports, baud rate as high as 115200bps;An IRDA infrared data communication port
Ø Infrared communication port:one.
Ø Ethernet port:one 10M/100M Ethernet port, DM9000, with connection and transmission indicator lights
Ø  WI-FI interface: one, built-in, accordance with 802.11 b/g
Ø GPS module: one, global positioning
Ø  HSMMC card interface:one high-speed SD card interface, compatible of SD/MMC/MMC4.0 cards
Ø SD card interface: one ordinary SD card interface
Ø CF card interface:one , standard CF R3.0
Ø Camera interface:A 2mm-pitch double-socket for camerea expansion; the users may use this expansion slot to connect other models.
Ø Keyboard:3 external interrupt button, 5 scan button, 1 five-switch
Ø  EEPROM:two 12C interfaces:  24C08, 24C128
Ø JTAG interface:a standard 20-chip Multi-ICE JTAG interface , supporting the debugging of ADS1.2,SDT2.51,etc.
Ø RTC clock:internal real-time clock (with the back-up lithium battery)
Ø LED:power supply and several indicator lights.
Ø Reset circuit: combining the manual reset and chip reset; the chip is MAX811; the reset is stable and reliable
Ø Expansion interface:lead to the signal which users need, including the bus, interrupt, I/O signals, and so on.
Ø  Power interface:12V power supply, with power switch and indicator light.
n Software resources:
n The supporting operating system :
WinCE6.0;Linux2.6.21; Linux 2.6.24; Ubuntu 9.04; Android 0.9
n WinCE6.0 Operating System:
Ø BSP:WinCE 6.0 BSP
Ø Device Driver:Ethernet, USB Host, USB Slave, Serial Port, LCD, Touch Screen, TV OUT, Audio, SD/MMC port, IRDA, IDE, Camera, RTC, Keypad, MFC,CF,GPS,WI-FI and so on.
Supporting MP3 players and MP4 video player
Supporting a wide range of network applications, for instance: http
n Linux 2.6.24 Operating System:
Ø Kernel:Linux2.6.24 (u-boot)
Ø The System Leading Process:U-boot-1.1.6 (no need of JTAG, supporting SD card and NANDFLASH to start u-boot)
Ø debugging tool: DNW v0.60C
Ø  Cross Compile: cross-4.2.2-eabi、cross-3.4.1、cross-3.3.2
Ø The Document System:cramfs
Ø  GUI: QT
Ø  Device Driver:SD/MMC, Ethernet, LCD, Audio, Camera, VGA, USB host, UART, 1G Nand Flash, 128M DDR, TOUCH
Supporting MP3 audio player and MP4 video player
n Ubuntu 9.04 operating system
Ø Kernel:Linux2.6.29 (u-boot)
Ø debugging tool: DNW v0.60C、MoviNAND_Fushing_Tool;
Ø  Cross Compile: Arm-none-linux-gnueabi
Ø The Document System:Ext3
Ø  GUI: Ubuntu 9.04
Ø  Device Driver:SD/MMC, LCD, UART, 1G Nand Flash, 128M DDR, TOUCH
n Android 0.9 Operating System:
Ø debugging tool: DNW v0.60C, MoviNAND_Fushing_Tool;
Ø The Document System:Yaffs2
Ø  GUI: Android 0.9
n  Packing List
Ø CES-6410 Prototype core board:one ;(standard)
Ø CES-6410 Prototype backplane:one;(standard)
Ø CES-6410 Prototype  CD-ROM:one;(standard)
Ø TFT LCD:7’ touch screen; one; (standard)
Ø SUPER JTAG debugging end(with 20-core cable):one ;(standard)
Ø Parallel line(one-to-one):one;(standard)
Ø  Serial lines (Direct Connect Serial Line):one ;(standard)
Ø Cable (cross-line cable):one;(standard)
Ø  USB line:  one;(standard)
Ø 12V DC adapter:  one ;(standard)
Ø Touch pen:  one ;(standard)
Ø  SD card(standard)
Ø 1.3-mega pixel camera(standard)
Ø High-grade packing box(standard)
