edk10.1 在打开用edk7.1建立的工程时,update失败
我现在使用edk10.1 在打开用edk7.1建立的工程时,update失败,无法打开工程,而且我又没有edk7.1的注册码,网上也找不到, 哪位大牛,指点下
output(如下):
WARNING:MDT - Invalid path specified for ModuleSearchPath in XMP file. Please make sure that the directory specified exists.
ERROR:MDT - IPNAME:plb_ddr HW_VER:1.11.a - Can not find valid MPD
INFO:MDT - Check the following for possible causes of not finding MPD:
- If HW_VER is specified in MHS, it must follow literal form X.YY.Z
- There is no Ip with given name
- Ip exists but not that version
- Ip (directory) exists but 2.1.0 MPD file is not available
- Ip exist in myip directory (only pcores is supported)
ERROR:MDT - IPNAME pb_ac97 HW_VER:2.00.a - Can not find valid MPD
ERROR:MDT - IPNAME:plb_ddr INSTANCE: DDR_256MB_32MX64_rank1_row13_col10_cl2_5 - D:\verilog\slideshow_256mb\system.mhs line 185 - could not find the MPD!
ERROR:MDT - IPNAME pb_ac97 INSTANCE: Audio_Codec - D:\verilog\slideshow_256mb\system.mhs line 229 - could not find the MPD!
ERROR:MDT - D:\verilog\slideshow_256mb\system.mss line 86 - Can not find MDD for the driver ac97 2.00.a
INFO:MDT - Directories Searched :
- D:\verilog\slideshow_256mb\drivers/ac97_v2_00_a/data
- D:\verilog\slideshow_256mb\pcores/ac97_v2_00_a/data
- D:\Xilinx\10.1\EDK\sw\ThirdParty\drivers/ac97_v2_00_a/data
- D:\Xilinx\10.1\EDK\sw\ThirdParty\pcores/ac97_v2_00_a/data
- D:\Xilinx\10.1\EDK\sw\XilinxProcessorIPLib\drivers/ac97_v2_00_a/data
- D:\Xilinx\10.1\EDK\sw\XilinxProcessorIPLib\pcores/ac97_v2_00_a/data
- D:\Xilinx\10.1\EDK\sw\lib\drivers/ac97_v2_00_a/data
- D:\Xilinx\10.1\EDK\sw\lib\pcores/ac97_v2_00_a/data
ERROR:MDT - Can not find MDD for the driver ac97 2.00.a
- D:\Xilinx\10.1\EDK\sw\lib\pcores/ac97_v2_00_a/data |
