![Rank: 2](images/default/star_level2.gif)
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity largefilter is
port ( clock : in std_logic;
din0x : in std_logic_vector( 7 downto 0 );
coef0x : in std_logic_vector( 7 downto 0 );
result : out std_logic_vector( 15 downto 0 ));
end largefilter;
architecture str of largefilter is
component filter
din0x : in std_logic_vector( 7 downto 0);
coef0x : in std_logic_vector( 7 downto 0);
din4x : out std_logic_vector( 7 downto 0 );
coef4x : out std_logic_vector( 7 downto 0 );
end component;
signal coef4x,din4x,coef8x,din8x,coef12x,din12x,coef16x,din16x : std_logic_vector( 7 downto 0 );
signal r0x,r4x,r8x,r12x : std_logic_vector( 15 downto 0 );
begin
filter0 : filter port map ( clock,din0x,coef0x,din4x,coef4x,r0x);
filter1 : filter port map ( clock,din4x,coef4x,din8x,coef8x,r4x);
filter2 : filter port map ( clock,din8x,coef8x,din12x,coef12x,r8x);
filter3 : filter port map ( clock,din12x,coef12x,din16x,coef16x,r12x);
process(clock)
begin
if rising_edge(clock) then
result <= r0x + r4x + r8x + r12x ;
end if;
end process;
end str;
这是一个fir滤波器的程序,8bit输入,16bit输出.我想把他改为8bit输入,8bit输出,我该怎摸做?请高手指点一下.谢谢! |
