大家好,我原来用4.0画的图,转换到5.0 的,当与PCB的同步是出现这样的问题。请问什么意思。
Line 23 , Section *DEL_ATTRIBUTE*
"owerGround"
* WARNING: Processing command to delete attribute "owerGround" from Net $$$10761.
* The attribute is also inherited from PCB PCB.
* The change is not fully reconciled for cases where the schematic
* does not support hierarchical attributes. |
