ISE 11与Win7的兼容性问题
ISE 11与Win7的兼容性问题
官方对Win7的正式支持可能要等到13.x,目前12.x只是测试性的支持Win7;
偶现在还在用11,台式机是Win7(32bit)+ISE11.4,可以正常使用;笔记本新换的固态硬盘,装了Win7(32bit)+ISE11.4,死活用不起来;后来试验发现11.1是可以的,即不打11.4补丁正常,打了补丁反而不能用了;
主要症状为:
在使用CORE Generator时会提示无法访问某某.log文件:
  1. Welcome to Xilinx CORE Generator.
  2. Help system initialised.
  3. Opening project file C:\temp\coregen2\coregen.cgp.
  4. WARNING:sim:381 - Unable to determine location of PDF viewer
  5. Customizing IP...
  6. Finished Customizing.
  7. Generating IP...
  8. WARNING:sim:356 - The parameter 'BestPrecision' is disabled, its value will default from 'true' to 'false'.
  9. WARNING:sim:192 - Xco Parameter changed from (BestPrecision,true) to (BestPrecision,false) during Recustomization.
  10. xst log file C:\temp\coregen2\.\tmp\_cg\_bbx\fir_compiler_v5_0_fir_compiler_v5_0_xst_1_xst.log cannot be accessed.
  11. ERROR:coreutil - Exception caught when running XST synthesis!
  12. ERROR:coreutil - Failure to generate output products
  13. WARNING:coreutil - WARNING: Default charset GBK not supported, using ISO-8859-1 instead
  14. ERROR:coreutil:576 - An error occurred while running Java. Please examine the console or coregen log file for a specific IP related error.
  15. For more information please search the Xilinx Answers Database for this error: http://www.xilinx.com/support
  16. ERROR:coreutil - xst log file C:\temp\coregen2\.\tmp\_cg\_bbx\fir_compiler_v5_0_fir_compiler_v5_0_xst_1_xst.log cannot be accessed.
  17. Error found during generation.
复制代码
这个家伙真懒,什么也没留下。。。
原因已查明,原来是压缩包的问题,Xilinx_11.4_ISE_DS_nt.tar中有两个文件损坏,分别是11_1_DSPTools_nt.zip与11_4_ISESW_nt.zip损坏,总体来说是个乌龙球,
这个家伙真懒,什么也没留下。。。
