All the Questions and Answers below have appeared in one of Bob Willis editorial columns in EMP AMT Ireland Electronic Manufacturing Products or EM&T Electronic Manufacture and Test magazines in the United Kingdom or in Asian Electronic Engineer. Further editorial on electronic manufacture is available for inclusion in magazines throughout the world by contacting EPS.
Q Dear Bob - What type of thermocouple wire should I use for profiling surface mount boards ?
The wire most often used for this application is "K" type which is a twisted pair and used on most profilers. The "K" wire is used for temperature ranges between 150 C and is approximately -0.010". For occasional use an insulated wire may be used; for regular continuous use a higher temperature insulation wire.
Q Dear Bob - We use one profile for all our surface mount products we have a convection oven is this OK ?
Well it is fair to say that a convection oven can provide single profile for all products large and small. But it is poor practice as inevitably some products will be in the liquid state for an unnecessary period of time increasing intermetallic thickness affecting solderability for second side reflow and possibly component damage. Be a SMART engineer not a lazy one!
Q Dear Bobby - How should thermocouple junctions be fixed to the board surface ?
There are three methods: adhesive Kapton tape and high temperature solder. The best is quite simply the last but do not bury the probe in a pile of solder as this will affect temperature. You may need to use an activated flux to make the wire wet.
Q Dear Bob - When profiling a reflow process should you use a fully populated board ?
Yes always. You may find that soldering is successful with a profile developed with a sample board but have a look at the voiding in the joints. It is difficult sometimes to get a populated board if you are a sub-contractor customers are loath to let you have one. Insist this will help you provide a better quality and potentially more reliable product to your customer.
Q Dear Mr Willis - I keep hearing that nitrogen is beneficial particularly with low residue solder paste how can I justify the cost ?
Most people justify the cost on changing to no clean or on quality grounds but that is difficult to show a cost saving benefit. The best way to justify the cost is by the use of copper based finished boards which will cost less than tin/lead. Check out the guide to nitrogen video available from the SMART Group it includes interviews with Colin Lea and Chris Tanner.
Q Dear Bob - I would like to purchase a Mole to profile my reflow oven what should I look for in the equipment ?
First of all Mole Kick and Datapaq are all trade names for the mid to top end profile units on the market. Generally the price increases with the number of thermocouple inputs to the data logger. The high end units also have excellent software for manipulating data. The cheaper units between 6-800 pounds sterling only have very basic software. It depends on what temperature measurements you want to do in production. I personally use an ECD Mole for running all my profiles on ovens wave soldering systems and even the oven at home!!. |
