请大虾们帮帮忙,修改下<<三人表决器>>VHDL代码的错误处
ENTITY maj IS PORT(a,b,c : IN BIT; m : OUT BIT); END maj; --Dataflow style architecture ARCHITECTURE concurrent OF maj IS BEGIN --selected signal assignment statement (concurrent) WITH a&b&c SELECT m <= '1' WHEN "110"|"101"|"011"|"111",'0' WHEN OTHERS; END concurrent; --Structural style architecture ARCHITECTURE structure OF maj IS --declare components used in architecture COMPONENT and2 PORT(in1, in2 : IN BIT; out1 : OUT BIT); END COMPONENT; COMPONENT or3 PORT(in1, in2, in3 : IN BIT; out1 : OUT BIT); END COMPONENT; --declare local signals SIGNAL w1, w2, w3 : BIT; BEGIN --component instantiation statements. --ports of component are mapped to signals --within architecture by position. gate1 : and2 PORT MAP (a, b, w1); gate2 : and2 PORT MAP (b, c, w2); gate3 : and2 PORT MAP (a, c, w3); gate4 : or3 PORT MAP (w1, w2, w3, m); END structure; --Behavioural style architecture using a look-up table ARCHITECTURE using_table OF maj IS BEGIN PROCESS(a,b,c) CONSTANT lookuptable : BIT_VECTOR(0 TO 7) := "00010111"; VARIABLE index : NATURAL; BEGIN index := 0; --index must be cleared each time process executes IF a = '1' THEN index := index + 1; END IF; IF b = '1' THEN index := index + 2; END IF; IF c = '1' THEN index := index + 4; END IF; m <= lookuptable(index); END PROCESS; END using_table; 我在编译的时候,提示错误: VHDL syntax error:choice value length [3] must match selector expression value length [0]
00
