MTK短信开发详解(三)
MTK短信开发详解(三)
MTK短信开发详解(三)
2.3.6、短信发送请求
   void mmi_frm_sms_send_sms_req(void)
       /* check SC: get SC address, inMsg keeps the flag */
       if ((sendSMS->sendcheck & MMI_FRM_SMS_SC) != MMI_FRM_SMS_SC)
           [... 首次进入 ...]
           return;
       /* check DA: show input screen, inMsg keeps the number */
       if ((sendSMS->sendcheck & MMI_FRM_SMS_DA) != MMI_FRM_SMS_DA)
           [...二次进入, 弹出号码输入框...]
           else if ((strlen((S8*) sendSMS->number) == 0) && ((sendSMS->sendrequire & MMI_FRM_SMS_REPLY) == 0))
               if (GetCurrScrnId() != SCR_ID_MSG_NUMBER)
                   mmi_frm_sms_entry_number();
               return;
           sendSMS->sendcheck = MMI_FRM_SMS_DA;
       /* check validity of DA */
       /* check FDL: when FDN on */
           [...号码输入完毕, 按[确认]到此...]
           [...短信内容编码...]
           result = mmi_frm_sms_pack_sms();
               [...绘制发送短信发送界面...]
               mmi_frm_sms_entry_send();
               [...设置短信发送回调...]
               SetProtocolEventHandler(mmi_frm_sms_send_sms_rsp, PRT_MSG_ID_MMI_SMS_SEND_MSG_RSP);
               SetProtocolEventHandler(mmi_frm_sms_abort_sms_ind, PRT_MSG_ID_MMI_SMS_SEND_ABORT_START_IND);
               [...(如果是长短信,循环)发送...]
                   for (i = 0; i < j; i++)
                       mmi_frm_sms_send_sms_seg();
   void mmi_frm_sms_send_sms_seg(void)
       MMI_FRM_SMS_SEND_MSG_REQ_STRUCT *sendSms;
       mmi_frm_sms_send_message(MOD_MMI, MOD_L4C, 0, PRT_MSG_ID_MMI_SMS_SEND_MSG_REQ, (oslParaType*) sendSms, NULL);
2.3.7、短信发送回调
无论发送是否成功(或者[取消]),  最后返回并高亮[写短信]菜单项:HighlightWMessageHandler()。
   [SMSMsg.c]
   void mmi_frm_sms_send_sms_rsp(void *inMsg)
           mmi_frm_sms_callback_action((void*)number, sendResult);
   [SmsPsHandler.c]
   void mmi_msg_send_msg_rsp(void *number, module_type mod, U16 result)
       switch (result)
           case MMI_FRM_SMS_OK:
               [... 设置跳转节点 ...]
               else if (IsScreenPresent(SCR_ID_MSG_WRITE))
                   SetMessagesScrnIdToDelHistoryNodes(SCR_ID_MSG_WRITE);
               [... 删除历史屏幕, 返回[写短信]...]
               if (g_msg_cntx.msg_send_info.CurrSendSmsNumbers == g_msg_cntx.msg_send_info.TotalSendSmsNumbers)
                   DeleteMessagesHistoryNodes();
                   mmi_frm_sms_delete_screen_history();
完整版本请见 http://www.51qianru.cn/bbs/
                                                        曙海教育
                                                曙海嵌入式学院3G通信培训中心
                                            (MTK培训,Android培训,iPhone培训)
                                                电话:021-51875830
                                                网址:http://www.51qianru.cn
                                                    讲师:李现路
                                              版权所有-曙海教育 转发请注明出处
