用FPGA驱动AD7714程序编译出错,谁帮帮忙指点一下
END AD7714xiaosong;苏州百度优化
ARCHITECTURE AD7714DATA OF AD7714xiaosong IS
SIGNAL Read_AD7714DATA:std_logic_vector(23 downto 0);
SIGNAL AD7714in_DATA:std_logic_vector(7 downto 0);
BEGIN
PROCESS(clk)
VARIABLE i:INTEGER RANGE 0 TO 6;
VARIABLE m:INTEGER RANGE 0 TO 23;
VARIABLE n:INTEGER RANGE 0 TO 6; --读数据
BEGIN苏州百度优化
AD7714pol<='1'; --初始化
AD7714sync<='1';
AD7714standby<='1';
AD7714buffer<='1';
AD7714cs<='0';
AD7714reset<='1';
IF(clk'EVENT and clk='1')THEN
IF n<8 THEN
CASE n IS
秀媚的个性签名! 苏州百度
http://www.qingyunseo.com |
