封装标准介绍(简化版)(二)
封装标准介绍(简化版)(二)
· LQFP:
32L LQFP, 7.00 x 7.00 x 1.40mm body size
64L LQFP, 10.00 x 10.00 x 1.40mm body size
80L LQFP, 12.00 x 12.00 x 1.40mm body size
100L LQFP, 14.00 x 14.00 x 1.40mm body size
64L LQFP, 14.00 x 14.00 x 1.40mm body size
128L LQFP, 14.00 x 20.00 x 1.40mm body size
144L LQFP, 20.00 x 20.00 x 1.40mm body size
160L LQFP, 24.00 x 24.00 x 1.40mm body size
208L LQFP, 28.00 x 28.00 x 1.40mm body size
256L LQFP, 28.00 x 28.00 x 1.40mm body size
· LQFP EXP PAD:
128L LQFP EXP PAD, 20.00 x 20.00 x 1.40mm body size
· MDIP:
8L MDIP, 250.00 x 386.50 x 130.00mils body size
14L MDIP, 250.00 x 755.00 x 135.00mils body size
40L MDIP, 550.00 x 2056.50 x 145.00mils body size
24L MDIP, 540.00 x 1250.00 x 225.00mils body size
24L MDIP, 288.00 x 1165.00 x 130.00mils body size
32L MDIP, 540.00 x 1650.00 x 150.00mils body size
· METAL LCC:
28L METAL LCC, 445.00 x 445.00 x 132.00mils body size
84L METAL LCC, 1145.00 x 1145.00 x 132.00mils body size
· METAL QUAD:
80L METAL QUAD, 13.79 x 19.79 x 2.64mm body size
96L METAL QUAD, 1335.00 x 1335.00 x 140.00mils body size
132L METAL QUAD, 935.00 x 935.00 x 140.00mils body size
128L METAL QUAD, 13.79 x 19.79 x 2.64mm body size
304L METAL QUAD, 39.64 x 39.64 x 3.81mm body size
· MICRO-ARRAY:
9L MICRO-ARRAY, 2.00 x 2.00 x 1.00mm body size
49L MICRO-ARRAY, 4.00 x 4.00 x 1.00mm body size
· MICROSMD:
5L MICROSMD, 1.01 x 1.36 x 0.94mm body size
8L MICROSMD, 1.56 x 1.56 x 0.99mm body size
4L MICROSMD, 0.78 x 0.78 x 0.45mm body size
4L MICROSMD, 0.78 x 0.90 x 0.70mm body size
8L MICROSMD, 1.28 x 1.28 x 0.85mm body size
8L MICROSMD, 1.28 x 1.28 x 0.90mm body size
10L MICROSMD, 2.00 x 2.50 x 0.94mm body size
5L MICROSMD, 1.56 x 1.61 x 0.85mm body size
4L MICROSMD, 1.01 x 1.01 x 0.60mm body size
14L MICROSMD, 2.10 x 2.40 x 0.60mm body size
4L MICROSMD, 1.08 x 1.08 x 0.50mm body size
4L MICROSMD, 1.03 x 1.41 x 0.60mm body size
4L MICROSMD, 1.03 x 1.03 x 0.35mm body size
4L MICROSMD, 1.03 x 1.03 x 0.25mm body size
· MINI SOIC:
8L MINI SOIC, 118.00 x 118.00 x 34.00mils body size
· MINI SOIC EXP PAD:
8L MINI SOIC EXP PAD, 118.00 x 118.00 x 34.00mils body size
· PBGA:
256L PBGA, 27.00 x 27.00 x 2.13mm body size
313L PBGA, 35.00 x 35.00 x 2.33mm body size
481L PBGA, 40.00 x 40.00 x 2.38mm body size
288L PBGA, 23.00 x 23.00 x 1.87mm body size
· PLCC:
20L PLCC, 350.00 x 350.00 x 145.00mils body size
28L PLCC, 450.00 x 450.00 x 145.00mils body size
32L PLCC, 451.00 x 551.00 x 109.00mils body size
44L PLCC, 650.00 x 650.00 x 145.00mils body size
52L PLCC, 750.00 x 750.00 x 145.00mils body size
68L PLCC, 950.00 x 950.00 x 145.00mils body size
84L PLCC, 1150.00 x 1150.00 x 145.00mils body size
· PPGA:
302L PPGA, 47.90 x 52.98 x 6.40mm body size
· PQFP:
80L PQFP, 14.00 x 20.00 x 2.70mm body size
44L PQFP, 10.00 x 10.00 x 1.75mm body size
44L PQFP, 10.00 x 10.00 x 2.00mm body size
132L PQFP, 950.00 x 950.00 x 140.00mils body size
196L PQFP, 1350.00 x 1350.00 x 140.00mils body size
60L PQFP, 14.00 x 14.00 x 2.70mm body size
100L PQFP, 14.00 x 14.00 x 2.00mm body size
100L PQFP, 14.00 x 20.00 x 2.70mm body size
208L PQFP, 28.00 x 28.00 x 3.37mm body size
240L PQFP, 32.00 x 32.00 x 3.40mm body size
304L PQFP, 40.00 x 40.00 x 3.80mm body size
· PSOP:
8L PSOP, 155.00 x 194.00 x 58.00mils body size
16L PSOP, 155.00 x 389.00 x 58.00mils body size
44L PSOP, 11.00 x 15.90 x 3.30mm body size
· SBGA:
352L SBGA, 35.00 x 35.00 x 1.40mm body size
168L SBGA, 23.00 x 23.00 x 1.38mm body size
560L SBGA, 42.50 x 42.50 x 1.54mm body size
304L SBGA, 31.00 x 31.00 x 1.70mm body size
192L SBGA, 25.00 x 25.00 x 1.39mm body size
· SC-70:
L SC-70, 1.25 x 2.00 x 0.90mm body size
· SHELLOP:
25L SHELLOP, 4.17 x 4.17 x 0.82mm body size
36L SHELLOP, 5.52 x 5.84 x 0.82mm body size
· SIP:
11L SIP, 638.00 x 1107.00 x 130.00mils body size
SOIC NARROW:
8L SOIC NARROW, 154.00 x 193.00 x 57.00mils body size
· SOIC WIDE:
14L SOIC WIDE, 295.20 x 354.00 x 90.60mils body size
40L SOIC WIDE, 296.00 x 606.00 x 95.00mils body size
28L SOIC WIDE, 346.00 x 714.00 x 88.00mils body size
· SOJ:
8L SOJ, 300.00 x 706.00 x 92.00mils body size
32L SOJ, 296.00 x 818.00 x 88.00mils body size
· SOP EIAJ TYPE II:
14L SOP EIAJ TYPE II, 5.30 x 10.10 x 1.80mm body size
24L SOP EIAJ TYPE II, 5.30 x 15.24 x 2.20mm body size
· SOT-223:
4L SOT-223, 140.00 x 256.00 x 63.00mils body size
5L SOT-223, 3.56 x 6.50 x 1.60mm body size
· SOT-23:
3L SOT-23, 114.00 x 51.00 x 35.00mils body size
6L SOT-23, 63.00 x 115.00 x 40.00mils body size
8L SOT-23, 2.20 x 3.50 x 1.20mm body size
· SSOP:
6L SSOP, 296.00 x 607.00 x 92.00mils body size
44L SSOP, 296.00 x 706.00 x 92.00mils body size
16L SSOP, 153.50 x 193.00 x 57.00mils body size
56L SSOP, 295.00 x 725.00 x 90.00mils body size
· SSOP-EIAJ:
40L SSOP-EIAJ, 7.50 x 13.60 x 2.16mm body size
14L SSOP-EIAJ, 5.30 x 6.20 x 1.79mm body size
24L SSOP-EIAJ, 5.30 x 8.20 x 1.73mm body size
28L SSOP-EIAJ, 5.29 x 10.20 x 1.76mm body size
14L SSOP-EIAJ, 4.40 x 5.00 x 1.20mm body size
20L SSOP-EIAJ, 4.40 x 6.50 x 1.20mm body size
· TBGA:
208L TBGA, 15.00 x 15.00 x 1.10mm body size
· TEPBGA:
292L TEPBGA, 27.00 x 27.00 x 2.38mm body size
388L TEPBGA, 35.00 x 35.00 x 2.38mm body size
481L TEPBGA, 40.00 x 40.00 x 2.38mm body size
440L TEPBGA, 23.00 x 23.00 x 2.28mm body size
324L TEPBGA, 19.00 x 19.00 x 1.81mm body size
· TO 220:
3L TO 220, 400.00 x 590.00 x 180.00mils body size
9L TO 220, 400.00 x 590.00 x 180.00mils body size
11L TO 220, 788.00 x 689.00 x 177.00mils body size
7L TO 220, 400.00 x 590.00 x 180.00mils body size
· TO 252:
3L TO 252, 6.58 x 7.30 x 2.30mm body size
· TO 263:
11L TO 263, 788.00 x 501.00 x 177.00mils body size
5L TO 263, 400.00 x 390.00 x 179.00mils body size
9L TO 263, 400.00 x 390.00 x 180.00mils body size
· TO 92:
3L TO 92, 4.95 x 5.05 x 3.92mm body size
· TO-247 SINGLE GAUGE:
15L TO-247 SINGLE GAUGE, 19.00 x 11.50 x 2.54mm body size
· TQFP:
32L TQFP, 7.00 x 7.00 x 1.00mm body size
64L TQFP, 10.00 x 10.00 x 1.00mm body size
80L TQFP, 14.00 x 14.00 x 1.00mm body size
144L TQFP, 20.00 x 20.00 x 1.00mm body size
176L TQFP, 24.00 x 24.00 x 1.00mm body size
· TQFP EXP PAD:
32L TQFP EXP PAD, 7.00 x 7.00 x 1.00mm body size
64L TQFP EXP PAD, 10.00 x 10.00 x 1.00mm body size
· TSBGA:
680L TSBGA, 40.00 x 40.00 x 1.60mm body size
· TSOP1:
28L TSOP1, 11.80 x 8.00 x 1.00mm body size
· TSOT:
593. - 6L TSOT, 1.65 x 2.97 x 0.87mm body size
· TSSOP:
20L TSSOP, 4.40 x 6.50 x 1.05mm body size
24L TSSOP, 5.60 x 7.80 x 1.15mm body size
38L TSSOP, 6.10 x 12.50 x 0.90mm body size
· TSSOP EXP PAD:
14L TSSOP EXP PAD, 4.40 x 5.00 x 0.90mm body size
20L TSSOP EXP PAD, 4.40 x 6.50 x 0.90mm body size
28L TSSOP EXP PAD, 4.40 x 9.70 x 0.90mm body size
64L TSSOP EXP PAD, 6.10 x 17.00 x 0.90mm body size
10L TSSOP EXP PAD, 3.00 x 3.00 x 0.85mm body size
· UFBGA:
615. 100L UFBGA, 9.00 x 9.00 x 1.00mm body size
飞思卡尔汽车电子开发板专业研发团队 http://fxfreefly.taobao.com
