现如今龙芯世纪成功破解DALLAS系列典型单片机型号——DS2437单片机解密,实现了在IC解密技术上的又一质到质的飞跃。世纪芯提供专业的各类AVR系列IC解密、专用IC芯片解密、PLD芯片解密、SPLD芯片解密、FPGA/CPLD芯片解密等解密服务,下面是atmega6450V单片机的技术参考资料,有更多相关解密需求者请联系龙芯世纪。
DS2437的技术参考资料:
·Unique 1-WireTM interface requires only one
port pin for communication
·Provides unique 64-bit serial number to
battery packs
·Eliminates thermistors by sensing battery
temperature on-chip
·On-board A/D converter allows monitoring of
battery voltage for end-of-charge and end-ofdischarge
determination
·On-board integrated current accumulator
facilitates gas gauging
·Real-time clock in binary format
·40-byte nonvolatile user memory available for
storage of user data such as gas gauge and
manufacturing information
·Operating range -40°C to +85°C
·Applications include portable computers,
portable/cellular phones, consumer
electronics, and handheld instrumentation
DS2437功能的描述:
The DS2437 Smart Battery Monitor provides several functions that are desirable to carry in a batterypack: a means of tagging a battery pack with a unique serial number;a direct-to-digital temperature sensor which eliminates the need for thermistors in the battery pack;a real-time clock; and 40 bytes of nonvolatile EEPROM memory for storage of important parameters such as battery capacity, capacity remaining, and indication of battery cycling.Information is sent to/from the DS2437 over a 1-Wire interface, so that only one wire (and ground) needs to be connected from a central microprocessor to a DS2437. This means that battery packs need onlyhave three output connectors: battery power, ground, and the 1-Wire interface Because each DS2437 contains a unique silicon serial number, multiple DS2437s can exist on the same 1- Wire bus. This allows multiple battery packs to be charged or used in the system simultaneously.Applications for the smart battery pack monitor include portable computers, portable/cellular telephones,and handheld instrumentation battery packs in which it is critical to monitor rea performance. Used in conjunction with a microcontroller in the battery pack or host system, the DS2437provides a complete smart battery pack solution that is fully chemistry-independent. |
