ERROR:MapLib:978 - LUT6 symbol
DDR3_SDRAM/DDR3_SDRAM/mpmc_core_0/gen_paths.mpmc_data_path_0/gen_write_fifos
[3].gen_fifos.mpmc_write_fifo_0/next_push_is_word_rstpot2" (output
signal=DDR3_SDRAM/DDR3_SDRAM/mpmc_core_0/gen_paths.mpmc_data_path_0/gen_write
_fifos[3].gen_fifos.mpmc_write_fifo_0/next_push_is_word_rstpot2) has an
equation that uses input pin I2, which no longer has a connected signal.
Please ensure that all the pins used in the equation for this LUT have
signals that are not trimmed (see Section 5 of the Map Report File for
details on which signals were trimmed).
请问这是为什么啊? |
