UP3扳子编译出现错误,怎么解决啊
UP3扳子编译出现错误,怎么解决啊
Error: Can't generate netlist output files because the license for encrypted files is not available
Error: Quartus II EDA Netlist Writer was unsuccessful. 1 error, 0 warnings
        Error: Processing ended: Sat Jul 16 09:56:02 2005
        Error: Elapsed time: 00:00:02
Error: Quartus II Full Compilation was unsuccessful. 1 error, 226 warnings
我发现当我取消EDATool setting --->simulator中的tootl name 变为none时,就不会出错了。我同时也发现显示编译的窗口也取消了对EDA Netlist Write 和EDA Simulator Tool的编译。
那两个东西是干什么的啊,怎么解决啊?
我也出现这样的问题:
Error: Can't open encrypted VHDL or Verilog HDL file "F:/altera/last_all/system/car_monitor_system/car_monitor_system/cpu.v" -- current license file does not contain a valid license for encrypted file Error: Node instance "the_cpu" instantiates undefined entity "cpu" Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 80 warnings Error: Quartus II Full Compilation was unsuccessful. 2 errors, 80 warnings 我在start compilation时出现这样的问题,请问楼主和各位好心的哥哥姐姐是不是license的问题啊?谁有license,传给我一份好吗?我有急用,小妹这边谢了!邮箱:dream-sistertom.com
海内存知己,天涯若比邻!
你的license对第三方的EDA工具不支持。
在交流中前进,共同实现nios的应用。
