NIOS调试的时候遇到选择下载电缆的问题
在DEBUG AS NIOSII HARDWARE 时出现问题!
错误提示如下,请问原因及解决方法!
You have more than one JTAG cable available so you must use the --cable option
to choose between them (or open the "Run/Run" or "Run/Debug" dialog and go to
the "Target Connection" tab).
No --cable option was provided (or you selected Automatic)
[em09]
喜欢自由的天空!
It looks like you may have multiple cables installed. To pick the intended cable eg. USB-Blaster, go to the menu bar and select Run -> Debug... Select the Target Connection tab and select the cable of your choice from the drop-down list for the JTAG cable field. Then click on Debug, to start the session.
爱,不是激情的随口
        情,不是瞬间的感动
