利用ASP操作串口
利用ASP操作串口
利用ASP操作串口
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
  <title> ASP读取串口数据 </title>
  < name="generator" content="editplus" />
  < name="author" content="" />
  < name="keywords" content="" />
  < name="deion" content="" />
  < language="VB">
  '//页面载入时自动打开串口进行监听
  'Sub Window_()
  '    MSComm1.PortOpen = True
  'End Sub
  '//打开串口进行监听
  Sub OpenPort()
   if Not MSComm1.PortOpen Then
  MsgBox "Port opened !", vbOKOnly, "Warning"
   Else
  MsgBox "Port already opened !", vbOKOnly, "Warning"
   End if
  End Sub
  '//关闭串口
  Sub ClosePort()
   if MSComm1.PortOpen Then
  MSComm1.PortOpen = False
  MsgBox "Port closed !", vbOKOnly, "Warning"
   Else
  MsgBox "Port already closed !", vbOKOnly, "Warning"
   End if
  End Sub
  < ID="clientEventHandlersJS" language="java">
  //串口事件驱动部分
  MSComm1_OnComm(){
   var fldWeight = frmView.txtWeight
   var strInput
   strInput = MSComm1.Input;
   alert(strInput);
   fldWeight.value == strInput;
   fldWeight.focus();
   return false;
  < language="java" FOR="MSComm1" EVENT="OnComm">
  //串口事件驱动关联
  MSComm1_OnComm()
</head>
<body>
  <object classid="clsid:648A5600-2C6E-101B-82B6-000000000014" id="MSComm1" codebase="MSCOMM32.OCX" type="application/x-oleobject"     style="left:54px;top:14px">
  <param name="_ExtentX" value="1005">
  <param name="_ExtentY" value="1005">
  <param name="_Version" value="393216">
  <param name="CommPort" value="1">
  <param name="DTREnable" value="-1">
  <param name="Handshaking" value="0">
  <param name="InBufferSize" value="1024">
  <param name="InputLen" value="0">
  <param name="NullDiscard" value="0">
  <param name="OutBufferSize" value="512">
  <param name="ParityReplace" value="63">
  <param name="RThreshold" value="14">
  <param name="RTSEnable" value="0">
  <param name="BaudRate" value="9600">
  <param name="ParitySetting" value="0">
  <param name="DataBits" value="7">
  <param name="StopBits" value="0">
  <param name="SThreshold" value="0">
  <param name="EOFEnable" value="-1">
  <param name="InputMode" value="0"></object>
  <form action="" method="post" id="frmView" name="frmView">
  <p>
  <input id="txtWeight" name="txtWeight" style="left:50px;top:17px"></p>
  <p>   </p>
  <p>
  <button ="OpenPort()" value="Open Port">Open COM Port</button>
  <button ="ClosePort()" value="Close Port">Close COM Port</button>
  </p>
  <p>
  </p>
  </form>
</body>
</html>
此文从网络整理而来,作者不详。
使用前请确保计算机中存在控件mscomm32.ocx
控件注册方法:
利用用Windows下的注册工具regsvr32注册该OCX控件,例如:
Regsvr32 … system目录\Mscomm32.ocx .
为了能正确使用该控件,需要修改注册表的信息,在注册表的在HKEY_CLASSES_ROOT\Licenses下建一主键:
4250E830-6AC2-11cf-8ADB-00AA00C00905
细节决定成败!
