XDP512输出比较问题,百思不得其解?
配置程序如下:
TSCR1_TEN = 0;        //Timer Disable:
TSCR1_TSWAI = 1;      //Timer Module Stops While in Wait
TSCR1_TSFRZ =1;       //Timer and Modulus Counter Stop While in Freeze   TSCR1_TFFCA = 0;      TSCR1_PRNT = 1;       //1 = Enables
TSCR2_TOI = 0;        //Timer Overflow Interrupt disable:
TSCR2_TCRE = 0;       //Timer Counter Reset disable:
PTPSR = 0b00001111;
TFLG2_TOF = 1;        //Timer Overflow Flag, Set when 16-bit free-running
TIOS  = 0b00000010;
TIE   = 0b00000010;   // Interrupt Enable
TFLG1 = 0b11111111;
TTOV  = 0b00000000;
TCTL1 = 0b00000000;
TCTL2 = 0b00001000;//
CFORC = 0b00000010; //通道1初始电平通过强制输出比较为0
TCTL1 = 0b00000000;
TCTL2 = 0b00000100; //通道1电平设为翻转      TC1 = 2000;
TSCR1_TEN = 10;        //Timer Enable:
#pragma CODE_SEG __NEAR_SEG NON_BANKED
void interrupt 9 Vtimch1Interrupt(void) // Enhanced timer channel 1  Interrupt
  asm("nop");
  TC1+=1999;
  TFLG1 = 0b00000010;//clear flag
问题1,
执行如下四条语句PIT的管脚寄存器仍然是1(PIT=255)即CFORC = 0b00000010;语句没有起作用,什么原因?
TCTL1 = 0b00000000;
TCTL1 = 0b00000000;
问题2,
比较匹配时中断是产生了,但是通道1的管脚并没有翻转(PIT=255)
问题3,
我用的是软件仿真,还有就是软件仿真和实际在芯片中运行的情况是完全一样吗?软件仿真会不会出错?
后来我又发现,必须把其他通道的输出比较管脚电平设为与通道0一样才好用,而不管通道0是否设为输出比较,即其他管脚电平受通道1设置的影响?请问是这样吗?
TCTL1 = 0b00000000;
TCTL2 = 0b00000001;
请各位知道一下,现在真的很郁闷?
还是先用硬件调试一下看看,是否与软件仿真的结果一致。
海纳百川  有容乃大
