NCVerilog设计秘诀与点评
NCVerilog设计秘诀与点评
NCVerilog设计秘诀与点评
1. 使用原因
很多朋友用 Mentor Graphics的modelsim。不过业界用的比较多的还是 Synopsys的VCS 和 Cadence的LDV(Logic design and verification)或者 IUS(Incisive simulation)。因为命令行的支持比较好。所以用的比较普遍。
2. 安装
先找到一个LDV的发行包。我用的是IUS54NT版本。安装好。
3. PLI接口
如果要用到Debussy的话,还需要把debussy提供的PLI接口库 libpli.dll 和 libpli.lib 拷贝到下面目录。
C:\Program Files\Cadence Design Systems\IUS\tools\lib
(红色括号与文字)是我的点评
1.
This approach allows completely transparent mixed language, mixed-level, and mixed cycle-event simulations. It also lays the foundation for mixed signal simulations.
2.External Interface:
(1) VHDL: VHPI,OMI
(2) Verilog: PLI, VPI, OMI
(Modelsim和VCS也有这个功能)
(PLI用的比较多,仿真器一般自带常用的PLI。)
(如果需要添加 FSDB支持,需要将debussy提供的libpli.dll和libpli.lib拷贝到tools/lib下面)
3. After elaboration, Single executable code stream, Affirma NC Simulator;
4.
Code Coverage ???
5. Verilog supported:
(1) OVI 2.0;
(2) IEEE 1364;
(3) Verilog-XL implementation;
6. NC-Verilog use: Library.Cell:View
cds.lib: This file contains statements that define your libraries and that map logical library names to physical directory paths.
hdl.var:This file defines which library is the work library.
7. You can write a setup.loc file to change the directories to search or to change the order of precedence to use when searching for the cds.lib and hdl.var files.
8. (仿真器的“构成-步骤”:ncvlog-parse,ncelab-elaborate,ncsim-simulate)
Single-step invocation: ncverilog : a parser called ncvlog; an elaborator called ncelab to build the model, and then invokes the ncsim simulator to simulate the model.
Multi-step invocation: invoke ncvlog, ncelab, and ncsim separately.
The cell binding mechanism is the major difference between the two invocation methods.
9.ncpack:change the properties of a database to make it read-only or add-only.
inca.architecture.lib_version.pak
inca.sun4v.091.pak
ncls utility: list the objects contained in the library system,
10. Library files protect:
(1) file locking mechanism: ncpack -unlock, to unlock a file
(2) signal handling mechanism ensures that any unexpected event,
11. cdsdoc:
To invoke the Cadence documentation window
tool_name -help
nchelp [options] tool_name message_code *******
ncsim> help [help_options] [command | all [command_options]]
11.
NCLaunch is a graphical user interface
nclaunch
SimVision Waveform Viewer,
12.
Many of these options have a corresponding plus option that you
can use on the ncverilog command.
ncvlog -ieee1364 => ncverilog +ncieee1364
When you run ncverilog, the parser is invoked with the -update option by default.
13. ncverilog:
(1) +debug. This option turns on read access to all objects in the design.
=> ncelab -access +r
(2) +ncaccess+. Use this option to selectively turn on different kinds of access.
e.x.: +ncaccess+r, +ncaccess+r+w
(3) +ncafile+access_ to specify an access file,
Three access:
Enabling Read, Write, or Connectivity Access to Simulation Objects.
14.
ncsim -licqueue: license queue
(当license不足的时候,用这个语句可以确保有人退出的时候,你能及时获得license)
The NC-Verilog simulator command language is based on Tcl.
TCL input +ncinput+filename or +tcl+filename;
15.
ncverilog.args in the snap.nc directory: command-line options of ncverilog
(所以前一次的命令在彼处有保存)
cds.lib and hdl.var file in the INCA_libs directory.
All tools share a common log file named ncverilog.log.
(查看log文件从而掌握运行时情况是最重要的debug方法之一)
Design units in files specified directly on the command line are compiled into the work library, and design units specified in -y libraries or -v library files are compiled into libraries that have the same names.
Writes the SNAPSHOT variable to the hdl.var file in the snap.nc directory to store the name of the snapshot used in this run.
---The SNAPSHOT variable in the hdl.var file is used to determine what snapshot was
created the last time this directory was used.
16. The next time you invoke ncverilog, it compares the current set of command-line options to the options stored in the ncverilog.args file. All of the plus options and dash options must be the same and in the same order for the options to be evaluated as equal.
17.
The ncverilog +ncuid+ncuid_name option enables ality in ncverilog that lets you run multiple simulations using the same intermediate objects and the same storage locations. The +ncuid+ option enables this ality by providing a unique ID name for each simulation.
18. (命令行参数含义)
ncverilog -h +all
+cdslib+path
+checkargs: Display a list of the arguments used on the command line.
+compile: Run ncvlog to compile the design, but do not invoke ncelab to elaborate the design or ncsim to simulate.
+debug:Turn on read access to all objects in the design.
This option is the same as +ncaccess+r.
+elaborate:Run ncvlog and ncelab
+expand: Expand all vectors.
+hdlvar+path
-h
+importrepare this Verilog design for import to VHDL.
+mixedlang:Search the library structure for a VHDL binding for instances that correspond to VHDL import.
+name+name: Use the specified name for the snapshot and for the INCA_libs/snap.nc directory.
+ncelabargs+stringass the specified ncelab command options to the elaborator before invoking it.
+ncelabexe+path_to_ncelab
+ncerror+warning_code:Increase the severity level of the specified warning message from warning to error.
+ncfatal+{warning_code | error_code}: Increase the severity level of the specified warning message or error message from warning or error to fatal.
+nclibdirname+directory_name: to change INCA_libs
+ncls_allist all of the objects in all libraries.
+ncls_dependents:Show the dependents for each object.
+ncls_snapshots: List all snapshot (SSS) objects.
+ncls_source:Show the source file dependents of each object.
+ncsimargs+string
+ncsimexe+path_to_ncsim
+ncuid+ncuid_name
+ncvlogargs+string
+noautosdfo not perform automatic SDF annotation.
+noupdate: prevents the writing of intermediate objects for design units that are up-to-date.
+ppe:Invoke the Post Processing Environment (PPE).
-R: Invoke the simulator (ncsim) to simulate the snapshot in the INCA_libs/worklib directory.
-r snapshot: Load the specified snapshot.
+sdf_orig_dirut the compiled SDF file in same location as the original SDF file.
+work+library_name:Use the specified library as the work library.
-c Compile and elaborate only. //same to Verilog-XL
20.
ncverilog:
+tcl+filename,+ncinput+filename:The NC-Verilog simulator command language is based on Tcl.
21.The compiled SDF dcache.sdf.test1.X).
Snapshots are always named lib.cell:ncuid_name
22. $test$plusargs
% ncverilog -R +userarg
% ncverilog -R +some_other_userarg
23. // To understand the concept of Snapshot
% ncverilog source.v +ncuid+test1
% ncverilog source.v +ncuid+test2
Two snapshots are generated in the INCA_libs/worklib directory:
worklib.top:test1 and worklib.top:test2.
you generate two snapshots using the following command lines:
% ncverilog source.v +elaborate
% ncverilog source.v +elaborate +ncaccess+r +nclibdirname+MYINCA_libs +name+debug
=> To simulate this snapshot:
% ncverilog -R +nclibdirname+MYINCA_libs +name+debug [+simulator_options]
24.Using -r to Simulate a Saved Snapshot:
% ncverilog -f verilog.vc +elaborate
% ncverilog -R -s
ncsim> run 1000
ncsim> save save1
ncsim> exit
//To simulate the saved snapshot, specify the snapshot name with the -r option,
% ncverilog -r worklib.save1:v // or: ncverilog -r save1
=> Simulation Environment:
If you want to restore the full Tcl debug environment when you restart with a saved snapshot, make sure that you save the environment with the save -environment filename command. This command creates a Tcl that captures the current breakpoints, databases, probes, aliases, and predefined Tcl variable values. You can then use the +ncinput+ option when you invoke ncverilog to execute the , or you can invoke ncverilog in interactive mode with the -s option and then use the Tcl source command to source the .
ncsim> save -environment ckpt1.tcl
ncverilog -s -r worklib.top:ckpt1 +ncinput+ckpt1.tcl
Note: If you set a breakpoint that triggers, for example, every 10 ns (that is, at time 10, 20, 30, and so on) and restart with a snapshot saved at time 15, the breakpoint triggers at 20, 30, and so on, not at time 25, 35, and so on.
25.
-R: The -R option lets you simulate the same snapshot multiple times using different simulator
command-line options.
-r: You can use the -r option to load a snapshot.
26.
SDF versions 1.0, 2.0, 2.1, and 3.0. For versions 2.0 and above, use the SDFVERSION statement in the header of the SDF file to specify the version.
SDF annotation is performed during elaboration. The elaborator recognizes $sdf_annotate system tasks in the design source files,
to override the default automatic SDF annotation mechanism and force annotation by using the +sdf_cmd_file+filename option
SDF: The NC-Verilog simulator reads only compiled SDF files.
(1) text SDF file, cpu.sdf,
(2) compiled cpu.sdf.X.
ncsdfc utility to automatically compile the SDF file.
Using $test$plusargs to Selectively Perform Annotations:
if ($test$plusargs( preroute ))
$sdf_annotate( preroute.sdf , m1);
else if ($test$plusargs( postroute ))
$sdf_annotate( postroute.sdf , m1);
The ncsdfc utility always compiles the SDF file with a precision of 1 fs. The elaborator annotates each module using the precision of the module or the precision set by using the ncelab -sdf_precision command_line option.
30.Turning Off SDF Annotation:
(1) Use the +noautosdf option on the ncverilog command line.
(2) Comment out the $sdf_annotate system task(s) in the Verilog source file.
31.
32.
You can use the -ieee1364 command-line option when you compile the design with ncvlog and elaborate the design with ncelab to check your code for
compatibility with the IEEE standard.
33. IEEE 1364 - 1995 Verilog: array of instances, bufif0 ar[3:0] (out, in, en); // array of tri-state buffers However, an array of instances must have a continuous range.
34. Set up your environment:
cds.lib
hdl.var
setup.loc
35.
Verilog: module, macromodule, or UDP
VHDL: entity, architecture, package, package body, or configuration
36.
internal intermediate objects:
library database file (.pak file)
37.
cds.lib:
DEFINE worklib ../worklib
DEFINE lib_std /usr1/libs/std_lib
You can have more than one cds.lib file.
Use the INCLUDE or SOFTINCLUDE statements to include a cds.lib file within a cds.lib If you are doing a pure VHDL or a mixed-language simulation, you must use the INCLUDE or SOFTINCLUDE statement in the cds.lib (System provide one)
SOFTINCLUDE is the same as the INCLUDE statement, except that no error messages are printed if the file does not exist.
38. Binding One Library to Multiple Directories:
DEFINE iclib ./ic_lib
ASSIGN iclib TMP ./ic_tmp_lib
UNASSIGN iclib TMP
38. -- can be used to check the content of the cds.lib
% nchelp -cdslib
39. hdl.lib
DEFINE WORK worklib
DEFINE VERILOG_SUFFIX (.v, .vg, .vb)
NCVLOGOPTS -messages -errormax 10 -update
40. hdl.var
% nchelp -hdlvar
41. view & snapshot
(1) The file mychip.v gets compiled into the default module view:worklib.mychip:module.
It is created after compile, (ncvlog)
(2) The elaborator generates a simulation snapshot for the design.
Intermediate objects created during the elaboration phase are stored in the .pak file.
The snapshot is also a Lib.Cell:View.
source =>(compile)=> module =>(elaborate) => snapshot => simulation,
细节决定成败!
确实不错  顶一下
