ADS+Smart-ICE来使用ATMEL AT76C902的问题
请问有人用过ADS+Smart-ICE来使用ATMEL AT76C902的吗?
我现在Multi-ICE server抓不到,所以自己写个.cfg档其内容如下:
[Title]
902
[tap 0]
ARM946E-S
[tap 1]
ARM7TDMI
; JTAG clock rate set to 1MHz, with adaptive clocking turned off
[Timing]
Low=2
High=2
Adaptive=OFF
AXD的设定,使用Multi-ICE.dll及它的default值,但设定完后,会跳出一个视窗显示:
RDI Severe Error 00259: Unable to stop target processor.
Check the server configuration matches the target system,
the target is powered up, not in reset and can operate at
the TCK setting used.
我参考手册及ARM网站够注意的地方,
也曾降低JTAG Bit Transfer Timing至20KHz,结果还是一样,
请问哪位大大有连线成功的,请告诉我设定还要注意什么地方,谢谢!! |
