有谁对basic scripting-----basic editor这块比较熟的,帮忙进来看看
我在libary中编辑了一个器件封装,特地在manage liabry attributes添加器件属性“制作:某某某”,想在basic scripts中以excel part list report的方式导出时可以在其中一个列中观察到。想必需要通过修改excel part list report 代码,但是不知道怎么修改,我不清楚它的固定参数像:ActiveDocument.Components、PartType、Name、Decal、Pins.Count等这哪里有定义,谁能够帮帮我?
excel part list report 的原代码是这样的:(红色部门为我添加的,蓝色处有请专家提点)
Sub Main
' Open temporarly text file
Randomize
filename = DefaultFilePath & "\tmp" & CInt(Rnd()*10000) & ".txt"
Open filename For Output As #1
' Output Headers
Print #1, " artType"; Space(22);
Print #1, "RefDes"; Space(24);
Print #1, " artDecal"; Space(22);
Print #1, " ins"; Space(6);
Print #1, "Layer"; Space(26);
Print #1, "Orient."; Space(24);
Print #1, "X"; Space(30);
Print #1, "Y"; Space(29);
Print #1, "SMD"; Space(7);
Print #1, "Glued"; Space(7);
Print #1, "Editor"; Space(0)
' Lock server to speed up process
LockServer
' Go through each component in the design and output values
For Each nextComp In ActiveDocument.Components
Print #1, nextComp.PartType; Space$(30-Len(nextComp.PartType));
Print #1, nextComp.Name; Space$(30-Len(nextComp.Name));
Print #1, nextComp.Decal; Space$(30-Len(nextComp.Decal));
Print #1, nextComp.Pins.Count; Space$(10-Len(nextComp.Pins.Count));
Print #1, ActiveDocument.LayerName(nextComp.layer); Space$(30-Len(ActiveDocument.LayerName(nextComp.layer)));
Print #1, nextComp.Orientation; Space$(30-Len(nextComp.Orientation));
Print #1, nextComp.PositionX; Space$(30-Len(nextComp.PositionX));
Print #1, nextComp.PositionY; Space$(30-Len(nextComp.PositionY));
Print #1, nextComp.IsSMD; Space$(10-Len(nextComp.IsSMD));
Print #1, nextComp.Glued; Space$(10-Len(nextComp.Glued));
Print #1, nextComp.???????(10-Len(nextComp.?????))
Next nextComp
' Unlock the server
UnlockServer
' Close the text file
Close #1
' Start Excel and loads the text file
On Error GoTo noExcel
Dim excelApp As Object
Set excelApp = CreateObject("Excel.Application")
On Error GoTo 0
excelApp.Visible = True
excelApp.Workbooks.OpenText FileName:= filename
excelApp.Rows("1:1").Select
With excelApp.Selection
.Font.Bold = True
.Font.Italic = True
End With
excelApp.Range("A1").Select
Set excelApp = Nothing
End
noExcel:
' Display the text file
Shell "Notepad " & filename, 3
End Sub |
有位朋友,为人明快,写文章做学问也就干净利落,令人羡慕。 |
