NL6000:无线调制解调器收发器
我没有找到相关的信息啊,这个主要用于哪个方面?
NL6000:无线调制解调器收发器
4月4日讯,RF Neulink公司推出无线调制解调器芯片的无线收发器系列NL6000。NL6000能进行局域网(LAN)连接。它的目标应用是各种远程信息处理,包括数据终端,水管理,遥控数据录入,油和气体监视,灌溉控制和安全系统
******************************************************************************************************** 有什么难题来求我,我定知无不言,言无不尽!
以下的文字,来自RF Neulink 公司的介绍.具体详情,请您参考该公司的资料.
RF Neulink debuts wireless modem
The RF Neulink NL6000 wireless data modem sets new standards for the wireless telemetry industry.
The modem and VHF or UHF transceiver are enclosed in one package. NL6000 radio channel data rates exceed typical land mobile radio (LMR) frequency standards while maintaining radio channel reliability.
A unique feature of the NL6000 is its ability to be IP addressable. The IP addressable feature, allows network connectivity of the NL6000 to Local Area Networks (LAN) via the onboard USB port.
This feature permits multiple NL6000s to be monitored and controlled via a users existing LAN.
This information can collectively be monitored and display in a central location.
Software upgrades and complete new product definitions can be downloaded through the Internet.
Due to several advanced signal processing techniques which correct for limitations of typical land mobile radios at high data rates, the NL6000 exhibits outstanding radio channel performance.
The NL6000 is ideal for any system where high performance RF specifications, high LMR data rates, and compact size are a requirement.
www.rfneulink.com
Specifications at a glance
Narrow band (12.5 KHz) or Wide Band (25 KHz) models
Radio Channel Performance: Greater than 95 percent reliability at 6db above 12db Sinad (.28uV)
Radio Channel Data Rates:
12 Kbps Narrow band (12.5 KHz)
22 Kbps Wide band (25 KHz)
Broadband Tx/Rx design: 26MHz VHF, 20 MHz UHF
RF output power 1-6 watts variable
Frequency Stability 1.5 PPM
Frequency Ranges: 136-162 MHz VHF
148-174 MHz VHF
400-420 MHz UHF
450-470 MHz UHF
