我使用 IMPACT将leon提供的LEON3比特流下载到ml510开发板上,使用1.1.49的GRMON进行调试。我使用load语句下载可执行文件,但总是报错说:
warning: stack pointer not set
IU in error mode (tt = 0x02 )
40000000 00000000 unimp
请问有没有哪位高手知道这是怎么回事啊?
另外,我注意到在GRMON连接到开发板后所显示的配置信息与所提供的文档中记录的不一样,虽然文档中是以LEON2为例,但是有的地方还是值得注意。
下面是我自己调试时显示的信息:
GRMON LEON debug monitor v1.1.49 evaluation version
copyright <c> 2004-2011 aeroflex Gaisler - all rights reserverd.
for latest updates, go to gaisler.~~~
Comments or bug-reports to ~~~~
This evaluation version will expire on 20/1/2012
try open device //./com1
###opened device //./com1
Device ID: : 0x510
GRLIB build version: 4090
initialising .........
detected frequency: 80 MHz
SRAM waitstates: 2
Component Vendor
LEON3 SPARC V8 Processor Gaisler Research
LEON3 SPARC V8 processor Gaisler Research
AHB Debug UART Gaisler Research
AHB Debug JTAG TAP Gaisler Research
SVGA Controller Gaisler Research
GR Ethernet MAC Gaisler Research
Fast 32-bit PCI Bridge Gaisler Research
PCI/AHB DMA controller Gaisler Research
DDR2 Controller Gaisler Research
LEON3 Debug Support Unit Gaisler Research
LEON2 Memory Controller European Space Agency
AHB/APB Bridge Gaisler Research
System ACE I/F controller Gaisler Research
AMBA Wrapper for System Monitor Gaisler Research
Generic APB UART Gaisler Research
Multi-processor Interrupt Ctrl Gaisler Research
Modular Timer Unit Gaisler Research
AMBA Wrapper for OC I2C-master Gaisler Research
General purpose I/O port Gaisler Research
SPI Controller Gaisler Research
PCI Controller Gaisler Research
PCI trace buffer Gaisler Research
PCI Arbiter European Space Agency
AHB status register Gaisler Research
Use command ¡ˉinfo sys¡ˉ to print a detailed report of attached cores
grmon[grlib]> inf sys
00.0:003 Gaisler Research LEON3 SPARC V8 Processor <ver 0x0>
ahb master 0
01.01:003 Gaisler Research LEON3 SPARC V8 Processor <ver 0x0>
ahb master 1
02.01:007 Gaisler Research AHB Debug UART <ver 0x0>
ahb master 2
apb: c0000700 - c0000800
baud rate 115200, ahb frequency 80.00
00.01:02e Gaisler Research DDR2 Controller <ver 0x0>
ahb: 40000000 - 60000000
ahb: fff00100 - fff00200
no sdram found
ahb: 60000000 - 80000000
ahb: fff00200 - fff00300
no sdram found
而文档中提供的信息是这样的:
Copyright (C) 2004,2005 Gaisler Research - all rights reserved.
For latest updates, go to ~~~~
Comments or bug-reports to ~~~~~
using port /dev/ttyS0 @ 115200 baud
initialising ..............
detected frequency: 40 MHz
Component Vendor
Leon3 SPARC V8 Processor Gaisler Research
Use command ’info sys’ to print a detailed report of attached cores
grmon> inf sys
00.01:003 Gaisler Research Leon3 SPARC V8 Processor (ver 0)
ahb master 0
02.01:007 Gaisler Research AHB Debug UART (ver 0)
ahb master 2
apb: 80000700 - 80000800
baud rate 115200, ahb frequency 40.00
03.01:01c Gaisler Research AHB Debug JTAG TAP (ver 0)
ahb master 3
04.01:012 Gaisler Research Simple 32-bit PCI Target (ver 0)
ahb master 4
05.01:005 Gaisler Research AHB interface for 10/100 Mbit MA (ver 0)
ahb master 5
00.04:00f European Space Agency LEON2 Memory Controller (ver 0)
ahb: 00000000 - 20000000
ahb: 20000000 - 40000000
ahb: 40000000 - 80000000
apb: 80000000 - 80000100
32-bit prom @ 0x00000000
64-bit sdram: 2 * 128 Mbyte @ 0x40000000, col 9, cas 2, ref 15.6 us
根据我的提示no sram found,而文档提供的是找到了sram,有可能我的找不到sram,但是我的开发板上连接了两个DDR2(虽然我不知道它们好不好使),我应该怎么解决这个问题呢,求高手指点! |
