P&E USB Multilink Universal USB-ML-UNIVERSAL 最新版仿真器
飞思卡尔8,16,32位芯片一网打尽!
大家可以了解下,后续有量了价格应该会比较好的,网店链接:http://item.taobao.com/item.htm?id=9258436737&
P&E’sUSB Multilink Universalis an all-in-one development interface which allows a PC access to the Background Debug Mode (BDM) on
Freescale MCU:
- HCS08,
- HC(S)12(X),
- RS08,
- ColdFire V1/+V1,
- ColdFire V2-4,
- Qorivva 5xxx,
- Kinetis ARM microcontrollers.
It connects between a USB port on a Windows machine and the standard debug connector on the target. The Freescale microcontrollers are supported via the multiple headers located on the USB Multilink Universal. The product photos to the left of this page show how the headers can be accessed by simply flipping open the plastic case. Ribbon cables suitable for a variety of architectures are included.
By using theUSB Multilink Universal, the user can take advantage of the background debug mode to halt normal processor execution and use a PC to control the processor. The user can then directly control the target’s execution, read/write registers and memory values, debug code on the processor, and program internal or external FLASH memory devices.
TheUSB Multilink Universalworks with P&E Microcomputer System's in-circuit debuggers and flash programmers to allow debug and flash programming of the target processor. For many of the supported processors, P&E has a set of interface libraries allowing the user to write their own Windows based application which interacts with P&E's debug interface. IAR, Codesourcery, Keil, and CodeWarrior software all support the use of P&E's USB Multilink Universal to develop and debug with Freescale's Kinetis ARM devices.
NOTE: For production usage, see either the[url=]Cyclone PRO[/url]or[url=]Cyclone MAX[/url]stand alone programmer and debug interface, depending on which processor you are working with.
FEATURES:
- USB interface from PC to Multilink allows for fast, easy programming and debugging -- with the ease and compatibility of the USB interface.
- Draws power from USB interface-- no separate power supply required (draws less than 1mA from the target).
- Target Voltage: 1.6V-5.25V
- Target Frequency: 16Khz-50Mhz
- Compatible with HCS08, RS08, HCS12, HC12, ColdFire V1/+V1, ColdFire V2-4, Qorivva MPC55xx/56xx, and Kinetis ARM families of microcontrollers.
- Includes USB cable, Type A Male to Type B Male, 6-ft.
- Auto-frequency detection + trimming capabilities for HCS08 devices.
- Auto-frequency detection for HC(S)12(X) devices.
- Generates programming voltage on RESET line for RS08 devices.
This interface is USB 2.0 compatible, however it is also backwards compatible with USB 1.1 ports.
飞思卡尔8/16/32位多功能开发板/下载器:
网站:http://www.lqist.cn,
淘宝店:http://shop36265907.taobao.com |
