SCI 如何自动发送数据
SCI 如何自动发送数据
这是我的程序;但一直不能自动显示字符串:
#include <hidef.h> /* for EnableInterrupts macro */
#include "derivative.h" /* include peripheral declarations */
unsigned char uchar;
unsigned int uint;
void InitMCG (void)
  MCGC2 = 0x00;
  while(!MCGSC_LOCK);
  MCGC2 = 0x36;
  while (!MCGSC_OSCINIT);
  MCGC1 = 0x38;
  while (MCGSC_IREFST);
  while(!MCGSC_LOCK);
  while (MCGSC_CLKST != 0x00);
void SciBrInit(void)
  SCI1BDH=0X00;
  SCI1BDL= 8000000/16/9600;              //设置波特率
  SCI1C1&=0xec;
void SciEnable(void)
   SCI1C2 = 0x2C;                                 //允许发送,允许接受 ,允许接收中断
   while(SCI1S1_TDRE==0);                         //发送一个空字节
   SCI1D=0xFF;
void SciSendByte(uchar value)
  while(SCI1S1_TDRE==0);                          //等待发送数据寄存器为空
  SCI1D=value;
void SciSendString(uchar *pt)                     //*pt是字符串的指针
  while(*pt)
    SciSendByte(*pt++);
void main()
  DisableInterrupts;
  SOPT1_COPT=0;                          //禁止看门狗
  SciEnable();
  InitMCG();
  SciBrInit () ;
  SciSendString("xitong");
  EnableInterrupts;
  for(;;)                                    //等待接收
interrupt 17 void SCIRecInt(void)
  uchar receivedata;
  while(SCI1S1_RDRF==0);
  receivedata=SCI1D;
  SciSendByte(receivedata);
