Be confidence with taylormade burner 2.0 irons
Confidence plays a huge role in putting. As you stand over putts on the practice green, visualize a trough leading from your putter to the cup and imagine hearing the sound of the ball dropping into the cup. Put down a chalk line to practice keeping your putter on-line. You can find a chalk line in a hardware store - it's that string carpenters snap to a surface to leave a chalk imprint. Practice keeping your taylormade burner 2.0 on line and hitting the sweet spot in your living room. Use an alignment tool (a ruler, for instance) and putting aids you can buy to affix to your putter's head that will help with centering the stroke. One of the most important factors in golf is the ball position. Don't forget it is the back of the ball that you are stroking with the putter, and not the centre. Remember that the back of the ball is in the middle of your stance, or slightly forward of this, if you are using a square-to-square stroke. Learn from each putt and remember the lesson. Practice, practice, practice with burner 2.0 irons!
