Library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
use IEEE.std_logic_signed.all;
package coeffs is
type coef_arr is array (0 to 16) of signed (8 downto 0);
constant coefs: coef_arr:=(
"111111001", "111111011", "000001101", "000010000",
"111101101", "111010110", "000010111", "010011010",
"011011110", "010011010", "000010111", "111010110",
"111101101", "000010000", "000001101", "111111011",
"111111001");
end coeffs;
Library IEEE;
use work.coeffs.all;
entity fir is
port(clk,reset: in std_logic;
sample: in signed ( 7 downto 0);
result: out signed ( 16 downto 0));
end fir;
architecture beh of fir is
begin
fir_main :process
type shift_arr is array (16 downto 0) of signed (7 downto 0);
variable tmp,old:signed( 7 downto 0);
variable pro:signed (16 downto 0);
variable acc:signed (16 downto 0);
variable shift:shift_arr;
begin
reset_loop:loop
for i in 0 to 15 loop
shift(i):=(others=>'0');
end loop;
result<=(others=>'0');
wait until clk'event and clk='1';
if reset='1' then exit reset_loop;
end if;
main:loop
tmp:=sample;
pro:=tmp*coefs(0);
acc:=pro;
for i in 15 downto 0 loop
old:=shift(i);
pro:=old*coefs(i+1);
acc:=acc+pro;
shift(i+1):=shift(i);
end loop;
shift(0):=tmp;
result<=acc;
end if;
end loop main;
end loop reset_loop;
end process;
end beh;
这个程序编译后,出现一个错误(%DLS-E-NoSuchAttr,Object kind UnconditionalLoop does not have attribute qSym;in GetAttr(qSym).)
这是什么原因啊 我用的是Max+plus II 10.21 |
