ERROR : Unexpected error while launching program. java.lang.RuntimeException: ERROR: MicroBlaze is under RESET. Check if the Reset input to MicroBlaze and its Bus Interfaces are connected properly
UNABLE to STOP MicroBlaze
at com.xilinx.sdk.targetmanager.internal.TM.connectToProcessor(Unknown Source)
at com.xilinx.sdk.debug.core.internal.AppRunner.run(Unknown Source)
这是SDK终端输出的错误,不知道怎么解决,请大神们解答!!!谢谢!!! |
