Pin Verification Fixture location
|2 |0 |
|3 |1 |
* = fixture found
Test 3976, Subtest 0, Module 2, Slot 5a FAILED.
KGD1 close relay test
Low Limit : 3.04948200E-04
Result Received : 1.74343467E-02 Volts
High Limit : 1.24695600E-02
Test 3976, Subtest 5, Module 2, Slot 5a FAILED.
KGD6 close relay test
low Limit : 8.65204100E-04
Result Received : 1.55741063E-02 Volts
High Limit : 1.50398600E-02
Test 3976, Subtest 0, Module 2, Slot 11a FAILED.
Result Received : 2.66922877E-02 Volts
Test 3976, Subtest 0, Module 3, Slot 3a FAILED.
Result Received : 2.49451804E-02 Volts
Test 3976, Subtest 1, Module 3, Slot 3a FAILED.
KGD2 close relay test
Low Limit : 3.34994100E-04
Result Received : 3.63115061E-02 Volts
High Limit : 1.26030200E-02
Test 3976, Subtest 5, Module 3, Slot 3a FAILED.
Low Limit : 8.65204100E-04
Result Received : 1.54009375E-02 Volts
Test 3976, Subtest 0, Module 3, Slot 4a FAILED.
Result Received : 1.63987447E-02 Volts
Test 3976, Subtest 1, Module 3, Slot 4b FAILED.
Result Received : 1.81340616E-02 Volts
Test 3976, Subtest 4, Module 3, Slot 4b FAILED.
KGD5 close relay test
Low Limit : 8.40924600E-04
Result Received : 1.97392297E-02 Volts
High Limit : 1.49226600E-02
Test 3976, Subtest 0, Module 3, Slot 9b FAILED.
Result Received : 2.04333565E-02 Volts
Test 3976, Subtest 2, Module 3, Slot 11b FAILED.
KGD3 close relay test
Low Limit : 5.72261400E-04
Result Received : 1.44465132E-02 Volts
High Limit : 1.36963000E-02
请帮忙分析一下,问题出在那里怎么解决,还有那个KGD是什么意思?
那个SLOT后面的A和B 是否是指SLOT所在的那那一张卡的上下的名称?
如果有资料的希望可以提供一些。谢谢了。。。 |
