ERROR:Pack:2310 - Too many comps of type "SLICEL" found ..怎么解决
关于system generator生成bitstream中ERROR ack:2310 - Too many .. SLICEL..刚使用这个,在关于system generator生成bitstream时,遇到错误,想请问下各位大侠这个错误怎么解决?非常感谢
当前使用xilinx ISE12.4
MATLAB2010B
芯片为spartan 3a xc3s200
错误提示如下:
WARNING:.........
ERROR ack:2310 - Too many comps of type "SLICEL" found to fit this device.
ERROR ack:18 - The design is too large for the given device and package.
Please check the Design Summary section to see which resource requirement for
your design exceeds the resources available in the device.
NOTE: An NCD file will still be generated to allow you to examine the mapped
design. This file is intended for evaluation use only, and will not process
successfully through PAR.
This mapped NCD file can be used to evaluate how the design's logic has been
mapped into FPGA logic resources. It can also be used to analyze
preliminary, logic-level (pre-route) timing with one of the Xilinx static
timing analysis tools (TRCE or Timing Analyzer).
Design Summary:
Number of errors: 2
Number of warnings: 108
Logic Utilization:
Number of Slice Flip Flops: 1,676 out of 3,584 46%
Number of 4 input LUTs: 3,031 out of 3,584 84%
Logic Distribution:
Number of occupied Slices: 1,990 out of 1,792 111% (OVERMAPPED)
Number of Slices containing only related logic: 1,990 out of 1,990 100%
Number of Slices containing unrelated logic: 0 out of 1,990 0%
*See NOTES below for an explanation of the effects of unrelated logic.
Total Number of 4 input LUTs: 3,511 out of 3,584 97%
Number used as logic: 2,809
Number used as a route-thru: 480
Number used for Dual Port RAMs: 136
(Two LUTs used per Dual Port RAM)
Number used as Shift registers: 86
The Slice Logic Distribution report is not meaningful if the design is
over-mapped for a non-slice resource or if Placement fails.
Number of bonded IOBs: 154 out of 195 78%
Number of BUFGMUXs: 1 out of 24 4%
Number of MULT18X18SIOs: 15 out of 16 93%
Number of RAMB16BWEs: 13 out of 16 81%
Average Fanout of Non-Clock Nets: 2.44
Peak Memory Usage: 203 MB
Total REAL time to MAP completion: 8 secs
Total CPU time to MAP completion: 8 secs
NOTES:
Related logic is defined as being logic that shares connectivity - e.g. two
LUTs are "related" if they share common inputs. When assembling slices,
Map gives priority to combine logic that is related. Doing so results in
the best timing performance.
Unrelated logic shares no connectivity. Map will only begin packing
unrelated logic into a slice once 99% of the slices are occupied through
related logic packing.
Note that once logic distribution reaches the 99% level through related
logic packing, this does not mean the device is completely utilized.
Unrelated logic packing will then begin, continuing until all usable LUTs
and FFs are occupied. Depending on your timing budget, increased levels of
unrelated logic packing may adversely affect the overall timing performance
of your design.
Mapping completed.
See MAP report file "controlboard_cw_map.mrp" for details.
Problem encountered during the packing phase.
ERROR:Xflow - Program map returned error code 2. Aborting flow execution... |
