求助HP3070 Unix系统问题[求助]急!!!
我这里的HP3070有一个多月没有开机用了,现在需要用它,今天一开机启动HP-Unix系统就出现如附图所示的错误信息,无法启动,哪位大哥知道这是怎么回事啊,怎么样才能解决这个问题啊?以下是一些错误信息: Attempting to boot Alternate Path... Attempted boot failed,continuing search Attempted to boot first valid device on builtin FWSCSI ... Attempted boot failed,continuing search Attempted to boot first valid device on GSC1 ... Module not found,continuing search Attempted to boot first valid device on PCI1 ... Attempted boot failed,continuing search Attempted to boot first valid device on GSC2 ... Module not found,continuing search Attempted to boot first valid device on PCI2 ... Attempted boot failed,continuing search Attempted to boot device 6 on builtin SESCSI ... Attempted boot failed,continuing search Attempting to boot first valid server on LAN... Search terminated. Boot terminated. --------Main Menu-------- Command Description ------- ------------ BOot [PRI|ALT|] Boot from specified path PRth [PRI|ALT|CON|KEY] [path>] Display or modify a path SERrch [DIsplay|IPL] [] Search for boot devices COnfiguration [] Access Configuration menu/commands INformation [] Access Information menu/commands SERvice [] Access Service menu/commands DIsplay Redisplay the current menu HElp [|] Display help for menu or command RESET Restart the system -------- Main Menu: Enter command > 在这里键入RESET后出现的提示是: Available memory (bytes) : 536870912 Good memory required (bytes) : 536870912 Primary boot path: PWSCSI.6.0 Alternate boot path: SESCSI.6.0 Console path: GRAPHICS(0) Keyboard path: PS2 CPU 0 WARNING: Self tests have been disabled as a result of FASTBOOT being enabled. To enable self tests, use the FASTBOOT command in the CONFIGURATION menu and reboot the system Processor is booting from first available device. To discontinue.press any key within 10 seconds.
[此贴子已经被作者于2005-10-28 18:41:02编辑过]
我从来没见过这样的问题,会不会有哪些线松掉了?如果和AGILENT签了维修合同,最好不过啦,哈哈
检查你的HUB,应该是没有连接或者没有HUB. 如果正常,重装系统.
怎么联系你?
我可帮助你,你可浏览WWW.UNICONSCIENTIFIC.COM.CN
