you can easily connect the I2C Wishbone core to the NIOS processor
1. Within SOPC builder, generate interface to user logic. 2. Select bus interface type: avalon register slave. 3. Add "i2c_master_top.v" design file. 4. Read port list from file. 5. Connect the signals as follow: wb_adr_i <=> address wb_dat_i <=> writedata wb_dat_o <=> readdata wb_we_i <=> write wb_stb_i <=> chipselect wb_cyc_i <=> chipselect wb_inta_o <=> irq wb_clk_i <=> clk wb_ack_o <=> waitrequest_n wb_rst_i <=> always0 arst_i <=> reset_n scl_pad_i <=> export scl_pad_o <=> export scl_padoen_o <=> export sda_pad_i <=> export sda_pad_o <=> export sda_padoen_o <=> export 6. Under timing tab, leave the setup, wait and hold settings at 0 cycles.
You can now access the I2C core via included "oc_i2c_master.h". 点击下载
