请求高手指点
请求高手指点
我编了这个程序运行的时候老是出同一个错误,不知道那里错了!小妹初次编程请各位高手指点一下吧!
library ieee;
use ieee.std_logic_1164.all;
entity ad8109 is
port(clk,ce,updata,datain,reset:in std_logic;
dataoutut std_logic;
out8ut std_logic_vector(7 downto 0));
end ad8109;
architecture struct of ad8109 is
component shift32
port(a,clk:in std_logic;
yut std_logic);
end component;
component sp
port(d,clk:in std_logic;
qut std_logic_vector(7 downto 0));
end component;
signal a:std_logic_vector(7 downto 0);
signal sw:std_logic;
begin
process(clk,ce,updata,reset)
begin
if reset='0' then
out8<="00000000";
dataout<='0';
elsif(clk'event and clk='0') then
 if ce='0'then
  if updata='1' then
  u1:shift32 port map (datain,clk,sw);
  dataout<=sw;
  elsif updata='0' then
  u2:sp port map (datain,clk,a);
  out8<=a;
  end if;
     end if;
end if;
end process;
end struct;
出的错误是:
error:terminnation notification:error in d:\anny\ad8109.vhd prevent further processing
两个模块也贴上来啊,帮你调试看下。
大浪淘沙
留下的全是金子
请谢谢您指点: shift32.vhd: library ieee; use ieee.std_logic_1164.all; entity shift32 is port(a,clk:in std_logic; yut std_logic); end shift32; architecture arch of shift32 is component dff port(d,clk:in std_logic; qut std_logic); end component; signal z:std_logic_vector(32 downto 0); begin z(0)<=a; g1:for i in 0 to 31 generate dffx:dff port map (z(i),clk,z(i+1)); end generate; y<=z(32); end arch; sp.vhd: library ieee; use ieee.std_logic_1164.all; entity sp is port(d,clk:in std_logic; qut std_logic_vector(7 downto 0)); end sp; architecture arch of sp is signal temp:std_logic_vector(7 downto 0); begin process(clk) begin if clk'event and clk='0' then temp(0)<=d; for i in 1 to 7 loop temp(i)<=temp(i-1); end loop; end if; end process; q<=temp; end arch; dff.vhd: library ieee; use ieee.std_logic_1164.all; entity dff is port(d,clk:in std_logic; qut std_logic); end dff; architecture arch of dff is begin process(clk,d) begin if clk'event and clk='0' then q<=d; end if; end process; end arch;
请您指点: Dff.vhd library ieee; use ieee.std_logic_1164.all; entity dff is port(d,clk:in std_logic; qut std_logic); end dff; architecture arch of dff is begin process(clk,d) begin if clk'event and clk='0' then q<=d; end if; end process; end arch; sp.vhd library ieee; use ieee.std_logic_1164.all; entity sp is port(d,clk:in std_logic; qut std_logic_vector(7 downto 0)); end sp; architecture arch of sp is signal temp:std_logic_vector(7 downto 0); begin process(clk) begin if clk'event and clk='0' then temp(0)<=d; for i in 1 to 7 loop temp(i)<=temp(i-1); end loop; end if; end process; q<=temp; end arch; shift32.vhd library ieee; use ieee.std_logic_1164.all; entity shift32 is port(a,clk:in std_logic; yut std_logic); end shift32; architecture arch of shift32 is component dff port(d,clk:in std_logic; qut std_logic); end component; signal z:std_logic_vector(32 downto 0); begin z(0)<=a; g1:for i in 0 to 31 generate dffx:dff port map (z(i),clk,z(i+1)); end generate; y<=z(32); end arch;
到XILINX 去开个WEBCASE 吧。 应该会有工程师帮你看的。 我上次就有个叫SALLY帮我把问题找到了。
谢谢!我试试看吧
哪个网站的论坛啊,我在xilinx没有找到论坛啊?
不好意思,对这方面我刚开始接触,什么都不懂呢
到下面这个地方去开
http://www.xilinx-china.com/support/clearexpress/websupport.htm
要先注册一下
谢谢!我进去了!非常感谢!
