在modelsim 5.7se中编译xilinx(ise7.1i)时出现的错误,请大家帮我会诊一下!
Release 7.1.01i - COMPXLIB H.38 Copyright (c) 1995-2005 Xilinx, Inc. All rights reserved.
XILINX = 'F:\ISE 7.1i' Library Source => 'F:\ISE 7.1i'
Compilation Mode = FAST Scheduling Smart-Model library installation & compilation for all architectures
Signature:- ------------------------------------------------------------------------------ compxlib -s mti_se -arch all -lib all -l all -dir f:\modelsim_5.7\xilinx_libs -log compxlib.log ------------------------------------------------------------------------------
Installing Xilinx Smart-Model.....
-> Environment variable LMC_HOME = F:\ISE 7.1i\smartmodelt\installed_nt -> Extracting model names from F:\ISE 7.1i\smartmodel\nt\image\sl_toc.dat -> Creating 'model.list' at current directory
Library Image directory : 'F:\ISE 7.1i\smartmodel\nt\image' Installaltion directory : 'F:\ISE 7.1i\smartmodel\nt\installed_nt' Running installer......
Compiling Xilinx HDL Libraries for ModelSim SE Simulator Language => verilog, vhdl Backing up setup files if any... Output directory => 'f:\modelsim_5.7\xilinx_libs'
--> Compiling verilog unisim library > Unisim compiled to f:\modelsim_5.7\xilinx_libs\unisims_ver
============================================================================== "START_COMPILE" Model Technology ModelSim SE vlog 5.7c Compiler 2003.03 Mar 13 2003 ** Error: (vlog-19) Failed to access library 'work' at "f:\modelsim_5.7\xilinx_libs\unisims_ver". No such file or directory. (errno = ENOENT) ** Error: (vlog-19) Failed to access library 'work' at "work". No such file or directory. (errno = ENOENT) ** Error: Library work not found. ** Error: Verilog Compiler exiting "END_COMPILE" ==============================================================================
ERROR:CAEInterfaces:356 - COMPXLIB[env]: directory not accessible for writing log file 'f:\modelsim_5.7\xilinx_libs\unisims_ver\cxl_unisim.log' : check READ/WRITE permissions > Library mapping successful, setup file(s) modelsim.ini updated
compxlib[unisims_ver]: 4 error(s), no warning(s)
ERROR:CAEInterfaces:562 - COMPXLIB[file]: unable to open info file 'f:\modelsim_5.7\xilinx_libs\unisims_ver\.xil_info'
--> Compiling verilog uni9000 library > Uni9000 compiled to f:\modelsim_5.7\xilinx_libs\uni9000_ver
"START_COMPILE"
** Error: (vlog-19) Failed to access library 'work' at "f:\modelsim_5.7\xilinx_libs\uni9000_ver".
"END_COMPILE"
ERROR:CAEInterfaces:356 - COMPXLIB[env]: directory not accessible for writing log file 'f:\modelsim_5.7\xilinx_libs\uni9000_ver\cxl_uni9000.log'
compxlib[uni9000_ver]: 4 error(s), no warning(s)
ERROR:CAEInterfaces:562 - COMPXLIB[file]: unable to open info file 'f:\modelsim_5.7\xilinx_libs\uni9000_ver\.xil_info'
--> Compiling verilog simprim library
> Simprim compiled to f:\modelsim_5.7\xilinx_libs\simprims_ver
"START_COMPILE"
** Error: (vlog-19) Failed to access library 'work' at "f:\modelsim_5.7\xilinx_libs\simprims_ver".
"END_COMPILE"
ERROR:CAEInterfaces:356 - COMPXLIB[env]: directory not accessible for writing log file 'f:\modelsim_5.7\xilinx_libs\simprims_ver\cxl_simprim.log'
compxlib[simprims_ver]: 4 error(s), no warning(s)
ERROR:CAEInterfaces:562 - COMPXLIB[file]: unable to open info file 'f:\modelsim_5.7\xilinx_libs\simprims_ver\.xil_info'
--> Compiling verilog XilinxCoreLib library
> compiling unisim library first
"START_COMPILE"
"END_COMPILE"
> XilinxCoreLib compiled to f:\modelsim_5.7\xilinx_libs\XilinxCoreLib_ver
"START_COMPILE"
** Error: (vlog-19) Failed to access library 'work' at "f:\modelsim_5.7\xilinx_libs\XilinxCoreLib_ver".
"END_COMPILE"
ERROR:CAEInterfaces:356 - COMPXLIB[env]: directory not accessible for writing log file 'f:\modelsim_5.7\xilinx_libs\XilinxCoreLib_ver\cxl_XilinxCoreLib.log'
compxlib[XilinxCoreLib_ver]: 4 error(s), no warning(s)
ERROR:CAEInterfaces:562 - COMPXLIB[file]: unable to open info file 'f:\modelsim_5.7\xilinx_libs\XilinxCoreLib_ver\.xil_info'
--> Compiling verilog smartmodel(unisim) library
"START_COMPILE"
"END_COMPILE"
> unable to parse initialization file. Check if the
file modelsim.ini is present in the current directory
with read/write permissions
> SWIFT Interface configuration procedure failed
> Unisim Smart-Models compiled to f:\modelsim_5.7\xilinx_libs\unisims_ver
"START_COMPILE:"
"END_COMPILE:" |
