library ieee; use ieee.std_logic_1164.all; entity notetabs is port (clk: in std_logic; toneindex: out integer range 0 to 15); end; architecture one of notetabs is signal counter: integer range 0 to 3; begin cnt8:process(clk) begin if counter=3 then counter<=0; elsif (clk'event and clk='1') then counter<=counter+1; end if; end process; search : process(counter) begin case counter is when 00 =>toneindex<=3; when 01 =>toneindex<=3; when 02 =>toneindex<=3; when 03 =>toneindex<=3; end case; end process; end;
警告:Ignored unnecessary INPUT pin 'clk'
怎么解决?有影响吗?
