请大家帮忙看看这个程序为什么XST通不过
请大家帮忙看看为什么用 XST走不通,错在哪里了?谢谢了
错误报告如下:
Analyzing Entity (Architecture ).
ERROR:Xst:827 - "C:/projects/qdq/qdq.vhd" line 46: Signal a cannot be synthesized, bad synchronous description.
Total memory usage is 76764 kilobytes
Number of errors : 1 ( 0 filtered)
Number of warnings : 2 ( 0 filtered)
Number of infos : 0 ( 0 filtered)
程序如下:
entity qdq is
Port ( clk : in std_logic;
rst : in std_logic;
a1 : in std_logic;
a2 : in std_logic;
a3 : in std_logic;
a4 : in std_logic;
a5 : in std_logic;
light1,light2,light3,light4,light5ut bit:='0';
cadeut std_logic_vector(3 downto 0):="0000");
end qdq;
architecture Behavioral of qdq is
signal a:std_logic_vector(4 downto 0);
signal scade:std_logic_vector(3 downto 0);
begin
process(rst,a1,a2,a3,a4,a5) --第 46行
begin
if (rst'event and rst='1') then a<="00000";
elsif ((a1='1')and(a2='0')and(a3='0')and(a4='0')and(a5='0')and(scade=0)) then a<=a1&a2&a3&a4&a5;
elsif ((a1='0')and(a2='1')and(a3='0')and(a4='0')and(a5='0')and(scade=0)) then a<=a1&a2&a3&a4&a5;
elsif ((a1='0')and(a2='0')and(a3='1')and(a4='0')and(a5='0')and(scade=0)) then a<=a1&a2&a3&a4&a5;
elsif ((a1='0')and(a2='0')and(a3='0')and(a4='1')and(a5='0')and(scade=0)) then a<=a1&a2&a3&a4&a5;
elsif ((a1='0')and(a2='0')and(a3='0')and(a4='0')and(a5='1')and(scade=0)) then a<=a1&a2&a3&a4&a5;
else a<="11111";
end if;
end process;
process(rst,a1,a2,a3,a4,a5) 改为 process(rst)试试。
