[求助]DSP/BIOS
[求助]DSP/BIOS
我在CCS3.1 的simulator写了一个dsp/bios 的小程序,在LOAD的时候弹出如下对话框,不知是何原因,怎么解决?是因为setup不正确吗?现在手上没有仿真器,只能用simulator,是不是bios的调试必须要仿真器啊?望高人指点。谢谢。
RTDX target application does not match emulation protocol!
Loaded program was created with an rtdx library which does not match the target device
我用CCS3.3、BIOS5.4,建28335的bios新建工程,总是出现下面的问题,您知道怎么解决么?
C:/CCStudio_v3.3/bios_5_41_10_36/packages/ti/bios/lib/lnkrtdx.a28FP<rtdx.o2
   8FP>" specifies ISA revision "C28FPU32", which is not compatible with ISA
   revision "C2800" specified in a previous file or on the command line
用图形化编译和txt格式的TCF编译也不行,都出现上面的这个不匹配问题。
谢谢!
