library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; entity clkgen is port(sysres,en1,clk:in std_ulogic; cntclk,keyclkut std_ulogic); end clkgen;
architecture rt1 of clkgen is component cnt10 port(reset,en,clk:in std_ulogic; carryut std_ulogic; qut std_ulogic_vector(3 downto 0)); end component; component cnt4 port(reset,en,clk:in std_ulogic; carryut std_ulogic; qut std_ulogic_vector(1 downto 0)); end component; signal cntclk_s:std_ulogic; begin u0:cnt10 port map(sysres,en1,clk,cntclk_s); u1:cnt4 port map(sysres,cntclk_s,clk,keyclk); cntclk<=cntclk_s; end rt1; 这段代码错误说error:line 13: unsupported feature error:enumeration type definition not supported in port declaration of the component instantiation statement. 我看例化的结构好象没什么问题嘛!请高手指点下 谢谢 |
