关于flash中擦写一个数据的问题,FLBPR无法访问!
本人最近写一个程序,在MC08HC908SR12中将flash中的一个数据块进行擦写。
源程序如下:
#include "Cpu.h"
#include "Events.h"
/* Include shared modules, which are used for whole project */
#include "PE_Types.h"
#include "PE_Error.h"
#include "PE_Const.h"
#include "IO_Map.h"
#define N 200
void DoEarseFlash(void);
void DoWriteFlash(void);
/*------------MOVE PROGRAM FROM FLASH TO RAM------------*/
void move(void(*p)(),byte size)
     byte *w;
     byte i=0;
     w=(byte *)0x0100;
     for(i=0;i<size;i++)
           *(w+i)=*((byte*)(p)+i);
/*---------MOVE DoEraseFlash form FLASH to RAM-----------*/
void EraseFlash(void)
    void(*a)();
    move(DoEarseFlash,0x3E);
    a=(byte *)0x0100;
    (*a)();
/*---------MOVE DoWriteFlash form FLASH to RAM-----------*/
void WriteFlash(void)
    void(*t)();
    move(DoWriteFlash,0x50);
    t=(byte *)0x0100;
    (*t)();
/*-------------DoEraseFlash:擦除指定flash区------------*/
    unsigned char i;
    FLBPR=0x01;        //设置flash保护区
    FLCR1=0b00000010;     //1->ERASE,0->MASS(页擦除)
    i=FLBPR;              //读FLBPR
    *((volatile unsigned char *)0xC000)=0x99;//向被擦写的单元写任意字符
    for(i=0;i<N;i++);   //延时10us
    FLCR1=0b00001010;     //1->HVEN (加高压)
    for(i=0;i<N;i++);  //延时时间必须>1.6ms
    FLCR1=0b00001000;     //0->Erase
    for(i=0;i<N;i++);   //10us
    FLCR1=0b00000000;     //0->HVEN(取消高压)
/*-----------DoWriteFlash:实际执行的写入函数-----------*/
void DoWriteFlash(unsigned int addr)
    unsigned char i;
    FLBPR=0x01;
    FLCR1=0b00000001;      //1->GM,编程状态
    i=FLBPR;               //读FLBPR
    *((volatile unsigned char *)(addr))=0x88;//0x88->C000,选中flash行
    FLCR1=0b00001001;      //1->HVEN
    *((volatile unsigned char *)addr)=0x88;//将数据写入相应的flash地址
    FLCR1=0b00001000;      //0->GM
void main(void)
  /**  * Processor Expert internal initialization. DON'T REMOVE THIS CODE!!! ***/
  PE_low_level_init();
  FLBPR=0x01;
  EraseFlash();
  DoEarseFlash();
  WriteFlash();
  DoWriteFlash(0xC000);
  FLBPR=0;
问题:
1.我的FLBPR不能修改,即FLBPR(FE09)=0x00不能将它置为1。而FLCR1(FE08)可以访问并且修改!
2.似乎从c000-c080的flash代码段没有被擦写,不知道我的程序是否有错,欢迎大家指正,谢谢!
[此贴子已经被作者于2005-11-30 22:16:37编辑过]
程序调试通过,基本功能实现,估计是因为flash保护而未能正确擦写,问题就归咎到FLBPR的访问上了!
