PORTA作为输入,却读不进数据
PORTA作为输入,却读不进数据
我的程序是:
void main(void) {
  /* put your own code here */
  //EnableInterrupts;
  byte test ;
  DDRB = 0xff; // PTB as output
  DDRA = 0x00;  //PTB as input
  cDelay(1000);  //延时
  cDelay(1000);  //延时
  for(;;){
   test = PORTA;  // read can address //
    if((test & 0x01)==0x01){
      PORTB_BIT4 = 1;
    }else{
      PORTB_BIT4 = 0;
hi  thank you for your help
sorry,以上程序是对的,可以读进来,我失误了
