Using cable "ByteBlasterMV [LPT1]", device 1, instance 0x00 Processor is already paused
Downloading 00000000 ( 0%) Downloaded 1KB in 0.0s
Verifying 00000000 ( 0%) Verify failed Leaving target processor paused
当下载时出现如上问题,我在QUARTUS2把数据线设置为OUTPIN,是不是这个问题?
如果是,那应该怎样设置双向PIN??? |
