[转帖]FIR滤波器的TI54X系列DSP的实现
代码部分:
* This function can be called in the c programs and in the *
* assmbly programs.                                        *
*             filename:  fir_filter                        *
*             author:skycanny                              *
*             date:2004,11,03                              *
*             argument1:the program coffcients pointer     *
*             argument2:the data coffcients pointer        *
*             argument3:the input pointer                  *
*             argument4:the output pointer                 *
*c syntax:                                                 *
*                   fir_filter(arg1,arg2,arg3,arg4)        *
*assembly syntax:                                        *
*                  frame -3          |return address|      *
*                  st arg2,*sp(0)    |     arg2     |<--sp *
*                  st arg3,*sp(1)    |     arg3     |      *
*                  st arg4,*sp(2)    |     arg4     |    *
*                  calld _fir_filter              *
*                  ld arg1,0,a                             *
*                  frame 3                                 *
_fir_filter:
        .title  "fir_filter.asm"
        .mmregs
        .include "main.inc"
        .global  _fir_filter
        .text
off_p           .set 0
off_m           .set 0
frame_size      .set off_p+11
;return address
arg_coff_dad    .set frame_size+1   ; arguments 2
arg_in_address  .set frame_size+2   ; arguments 3
arg_out_address .set frame_size+3   ; arguments 4
  .asg AR2,COFFBUF_P
  .asg AR3,INBUF_P
  .asg AR4,OUTBUF_P
   NOP
   NOP
   NOP
   PSHM ST0
   PSHM ST1
   PSHM BK
   PSHM AL
   PSHM AH
   PSHM BL
   PSHM BH
   PSHM AR0
   PSHM AR2
   PSHM AR3
   PSHM AR4
   SSBX FRCT
   MVDK *SP(arg_coff_dad),COFFBUF_P
   RPT  #K_FIR_SIZE2
   READA *COFFBUF_P+
   SSBX OVM
   STM #1,AR0
   MVDK *SP(arg_out_address),OUTBUF_P
   RPTZ A,#K_IN_SIZE-1
   STL  A,*OUTBUF_P+
   NOP
   MVDK *SP(arg_in_address),INBUF_P
   LDM OUTBUF_P,B
   ADD #K_FIR_SIZE2,B
   STLM B,OUTBUF_P
   STM #K_FIR_SIZE2,BK
   STM #K_IN_SIZE-K_FIR_SIZE2-1,BRC
   RPTBD fir_filter_loop-1
   NOP
   NOP
   LD #0,A
   RPT #K_FIR_SIZE2
   MAC  *COFFBUF_P+,*INBUF_P+,A
  ;计算前向通道
  ;将计算结果保存至预留区中
   STH A,*OUTBUF_P+
  ;系数归位
  ;将输入的地址指向下一次的开始位置
   LDM INBUF_P,B
   ADD #-K_FIR_SIZE2,B
   STLM B,INBUF_P
fir_filter_loop:
   NOP
   POPM AR4
   POPM AR3
   POPM AR2
   POPM AR0
   POPM BH
   POPM BL
   POPM AH
   POPM AL
   POPM BK
   POPM ST1
   POPM ST0
   NOP
   RET
   .end
