protel99菜鸟问题
protel99菜鸟问题
    学校的实验居然安排用protel99做图,可我一点也没有接触过这个软件,勉强完成连接,可是有一屏幕错误。我们做的是6116(2kX8)扩展成8KX16的存储器,用它做出pcb,哎,真的不会,对了,还有50pin的cpu(2),一个74ls138(1),下面有很多错误,不知道是什么意思,请大家指教(u?是6116,这些都不知道干吗用的,暂时叫着名字)
1 Error: Pin order data (PINS=1:[<pins>]) not in READ ONLY field 4. Pins sorted by pin-name.
1 Error: Part type must be entered in READ ONLY field 1: type=<part type>(<spice prefix>)
1 Error: Netlist data must be entered in READ ONLY field 5: netlist=<netlist data>
2 Error: Pin order data (PINS=1:[<pins>]) not in READ ONLY field 4. Pins sorted by pin-name.
2 Error: Part type must be entered in READ ONLY field 1: type=<part type>(<spice prefix>)
2 Error: Netlist data must be entered in READ ONLY field 5: netlist=<netlist data>
U? Error: Pin order data (PINS=1:[<pins>]) not in READ ONLY field 4. Pins sorted by pin-name.
U? Error: Part type must be entered in READ ONLY field 1: type=<part type>(<spice prefix>)
U? Error: Netlist data must be entered in READ ONLY field 5: netlist=<netlist data>
U? Error: Duplicate Designator ATTRIBUTE entered
