各位高手都来看看,帮个忙吧,谢谢
各位高手都来看看,帮个忙吧,谢谢
我写的一个VHDL程序,用simulator查看,发现输出没有变化
大虾看看哪里有问题?我是个新手
LIBRARY IEEE;
USE IEEE.std_logic_1164.ALL;
USE IEEE.std_logic_unsigned.ALL;
USE IEEE.std_logic_arith.ALL;
entity EL16 is
      port(vid_in:in std_logic_vector(3 downto 0);
           clk:in std_logic;
           vs,hs,selftestut std_logic;
           vid_outut std_logic_vector(3 downto 0));
end EL16;
architecture rtl of EL16 is
            type states is (st0,st1,st2,st3,st4);
            signal current_state,next_state:states:=st0;
            signal vid_temp:std_logic_vector(3 downto 0);
begin
         com:process(current_state)
begin
         case current_state is
         when st0=>next_state<=st1;
                               vs<='1';
                               hs<='0';
                               selftest<='0';
         when st1=>next_state<=st2;
                               vs<='1';
                               hs<='0';
                               selftest<='0';
         when st2=>next_state<=st3;
                               vs<='1';
                               hs<='1';
                               selftest<='0';
         when st3=>next_state<=st4;
                               vs<='1';
                               hs<='0';
                               selftest<='0';
                               vid_temp<=vid_in;
          when st4=>vs<='0';
                                hs<='0';
                                selftest<='0';
                                vid_temp<=vid_in;
         end case;
end process;
     clock:process(clk,current_state)
     VARIABLE cnt:integer RANGE 0 TO 3;
begin
         if clk'event and clk='1' then
           if current_state=st4 then
               if cnt=3 then
                cnt:=0;
               current_state<=st1;
               else
                cnt:=cnt+1;
               end if;
            else
             current_state<=next_state;
           end if;
         end if;
end process;
         vid_out<=vid_temp;
end rtl;
没人知道么???
