各位帮我看看这个程序,我是个初学者,就是变量赋值老有问题;
library ieee; use ieee.std_logic_1164.all; package page is function min(x,y: in std_logic_vector) return std_logic_vector ; end page; package body page is function min(x,y: in std_logic_vector) return std_logic_vector is variable temp:std_logic_vector(3 downto 0); begin if(x<y) then temp:=x; else temp:=y; end if; return temp; end function min; procedure vector_to_int (signal s: in std_logic_vector(7 downto 0); result:inout integer ) is variable t:integer :=1;----------------? begin for i in 1 to 7 loop t: = t*2; if(s(i)='1') then result:=result+1; end if; end loop; end procedure; end page; |
result:=result+1
应该是这里的问题
result:=result+t
