fixture can not be locked
fixture can not be locked after keyin'fix lock', and the system was no any response.
the compress air is ok, what's going on?
The system was shipped here two days ago.
and I found the connector J560a which power 24v dc to Pulldown solenoid Valve
was no connection. Where should it go to the support bay?
楼主可以空载fixture 看看是不是治具问题了,如果空载也不可以那可能就是系统卡挂了.
其实地上本没有路,走的人多了也便成了路
First check if testhead power is normal.
The connector should connect to J560a pin 1 ,2 on the system card.
if you can measure 24v .this meaning the fixture lock relay on system card is no problem .
you can try to unlock the valve , and clean it . it should work .
支持楼上说的,
其实地上本没有路,走的人多了也便成了路
这得看你公司常用第几组来控制,像Aauxconnect4,就接7.8,auxconnect5就接9,10
看一下fixture对应testhead的18排的38,39pin是否短接,正确的要短接的
■Test Fixture Software
http://www.tebosoft.com
sales@tebosoft.com
Tebo-ICT is a kind of very professional ICT and ATE fixture software. Chinese interface, designed in humanity, compatible with Win98/2000/NT/XP system, which is easy to operate and train. It can cope with all kinds of GERBER and buried via, positive and negative board materials; at the same time, it equip with many kind of CAD connector, which make it can easy to deal with data in short time. It is the best choice to make high density, complex ICT and ATE test fixture.
■Input:  1)Gerber Rs274D,Gerber Rs274X,DPF,HPGL,DXF ...
          2)CAD(ASCII): ODB++(*.tar,*.tgz,*.zip),GenCAD(*.cad), Cadence(*.cad),Fab FATF(*.asc,*.fat,*.fab),
                     Mentor(*.neu,*.vss), PADS(*.asc),PowerPCB(*.asc),Redac CADIF(*.paf),Protel(*.pcb)...
■Output: 1)ATE:AGILENT(3070),GENRAD(228X),TERADYNE(Z18XX,SPECTRUM),AEROFLEX(4200),TRI(8001)...
          2)ICT: TRI(518/5001),JET(200/300), TAKAYA(AT3200/3400),TESCON(piont-55/66,FOCUS-2000),
                 OKANO(FA-931,AT-01),SRC(3001,6001),HIOKI(1105),WILLTECH(WTX-3000)...
          3)Flying Probe: TAKAYA(APT-9000/9400/7400CN),SPEA(4040)...
          4)AOI: AGILENT(SP50/SP2),ORBOTECH(VT-9000)...
          5)AXI: HP5X  ...
[此贴子已经被作者于2006-5-20 11:31:48编辑过]
