--------------------------------------------------------------- -- FIR Digital Filter Design (DSP example) -- -- VHDL Data-Flow modeling -- KEYWORD: -- generate, array, range, constant and subtype ---------------------------------------------------------------
library IEEE;-- declare the library use IEEE.std_logic_1164.all; use IEEE.std_logic_arith.all;
entity FIR_filter is port(rst:instd_logic; clk:instd_logic; coef_ld:instd_logic; start:instd_logic; o_enable:instd_logic; bypass:instd_logic; Xn_in:in std_logic_vector(3 downto 0); Yn_in:instd_logic_vector(15 downto 0); Xn_oututstd_logic_vector(3 downto 0); Yn_oututstd_logic_vector(15 downto 0) ); end FIR_filter;
architecture BEH of FIR_filter is
constant K:integer := 4;-- circuit has four stages
-- use type and subtype to define the complex signals
subtype bit4 isstd_logic_vector(3 downto 0); subtype bit8 isstd_logic_vector(7 downto 0); subtype bit16 isstd_logic_vector(15 downto 0);
type klx4isarray (K downto 0) of bit4; type kx8isarray (K-1 downto 0) of bit8; type klx8is array (K downto 0) of bit8; type kx16isarray (K-1 downto 0) of bit16; type klx16isarray (K downto 0) of bit16;
-- define signal in type of arrays signalREG1, REG2, COEF: klx4; signalMULT8: kx8; signalMULT16: kx16; signalSUM: klx16; signalXn_tmp: bit4; signalYn_tmp: bit16;
begin
-- initialize the first stage of FIR circuit
REG2(K)<= Xn_in when (start='1') else (REG2(K)'range => '0'); REG1(K) <= (REG1(K)'range => '0'); SUM(K) <= Yn_in; COEF(K) <= Xn_in;
-- start the computation, use generate to obtain the -- multiple stages
gen8:for j in K-1 downto 0 generate
stages:process (rst, clk) begin if (rst='0') then REG1(j) <= (REG1(j)'range => '0'); REG2(j) <= (REG2(j)'range => '0'); COEF(j) <= (COEF(j)'range => '0'); MULT16(j) <= (MULT16(j)'range => '0'); SUM(j) <= (SUM(j)'range => '0'); elsif (clk'event and clk ='1') then REG1(j) <= REG2(j+1); REG2(j) <= REG1(j); if (coef_ld = '1') then COEF(j) <= COEF(j+1); end if; MULT8(j) <= signed(REG1(j))*signed(COEF(j)); MULT16(j)(7 downto 0) <= MULT8(j); if (MULT8(j)(7)='0') then MULT16(j)(15 downto <= "00000000"; else MULT16(j)(15 downto <= "11111111"; end if; SUM(j) <= signed(MULT16(j))+signed(SUM(j+1)); end if;
end process;
end generate;
-- control the outputs by concurrent statements
Xn_tmp <= Xn_inwhen bypass = '1' else REG2(0) when coef_ld = '0' else COEF(0);
Yn_tmp <= Yn_inwhen bypass = '1' else SUM(0);
Xn_out <= Xn_tmpwhen o_enable = '0' else (Xn_out'range => 'Z');
Yn_out <= Yn_tmpwhen o_enable = '0' else (Yn_out'range => 'Z');
end BEH;
