ISE调model的问题
ISE调model的问题
问题提示是:
# Model Technology ModelSim SE vlog 5.8b Compiler 2004.01 Jan 26 2004
# ** Error: (vlog-19) Failed to access library 'work' at "./modelsim_work".
# No such file or directory. (errno = ENOENT)
# ** Error: Library work not found.
# ** Error: Verilog Compiler exiting
# ** Error: d:/Modeltech_5.8b/win32/vlog failed.
# Error in macro ./tb_glr.fdo line 5
# d:/Modeltech_5.8b/win32/vlog failed.
#     while executing
# "vlog  glr_jjliu.v
# Load canceled
我的ini设置是:
[Library]
std = $MODEL_TECH/../std
ieee = $MODEL_TECH/../ieee
verilog = $MODEL_TECH/../verilog
vital2000 = $MODEL_TECH/../vital2000
std_developerskit = $MODEL_TECH/../std_developerskit
synopsys = $MODEL_TECH/../synopsys
modelsim_lib = $MODEL_TECH/../modelsim_lib
UNISIMS_VER = d:\Modeltech_5.8b\xilinx_libs\unisims_ver
SIMPRIMS_VER = d:\Modeltech_5.8b\xilinx_libs\simprims_ver
XILINXCORELIB_VER = d:\Modeltech_5.8b\xilinx_libs\XilinxCoreLib_ver
AIM_VER = d:\Modeltech_5.8b\xilinx_libs\abel_ver\aim_ver
CPLD_VER = d:\Modeltech_5.8b\xilinx_libs\cpld_ver
UNI9000_VER = d:\Modeltech_5.8b\xilinx_libs\uni9000_ver
UNISIM = d:\Modeltech_5.8b\xilinx_libs\unisim
SIMPRIM = d:\Modeltech_5.8b\xilinx_libs\simprim
XILINXCORELIB = d:\Modeltech_5.8b\xilinx_libs\XilinxCoreLib
AIM = d:\Modeltech_5.8b\xilinx_libs\abel\aim
PLS = d:\Modeltech_5.8b\xilinx_libs\abel\pls
CPLD = d:\Modeltech_5.8b\xilinx_libs\cpld
work = ./modelsim_work
stratix = modelsim_work
不知那位高人可以给予指点,多谢了!
是当前的工作目录WORK没有找到文件,建议设置系统的工作目录。在FILE菜单下有个改变目录的地方, 你需要重新设置一下。
